I'm servicing the amp on my subwoofer. Each of the two main AC capacitor filters(10mF 80V) have four terminals. The two capacitors are in series. I read the spec sheets on a different capacitor at Mouser and it stated that the two blank terminals should be isolated from either the positive or negative terminals. They are for mechanical support only. Yet, one capacitor has one of its blank terminals connected via a trace with its positive terminal and the negative terminal of the other capacitor. Is this a mistake in the design of the circuit board?
4 terminal capacitor is soldered wrong?
Re: 4 terminal capacitor is soldered wrong?
These seem to be 2-section electrolytic capacitors. Leave them connected as-is.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpic -
Can we see good clear pictures of the caps and the circuit board?I'm servicing the amp on my subwoofer. Each of the two main AC capacitor filters(10mF 80V) have four terminals. The two capacitors are in series. I read the spec sheets on a different capacitor at Mouser and it stated that the two blank terminals should be isolated from either the positive or negative terminals. They are for mechanical support only. Yet, one capacitor has one of its blank terminals connected via a trace with its positive terminal and the negative terminal of the other capacitor. Is this a mistake in the design of the circuit board?Never stop learning
View Me
I uploaded 3 pictures on OneDrive. I circled red the position of the two capacitors. I have not been able to find any info on the Soundia Capacitors. So I don't know if they are upto spec or not. But based on my measurements, capacitance is at 9mF, dissipation factor at 2.2, ESR at 100KHz is 0.3 Ω, ESR at 120Hz is 0.4 Ω. Both pretty much measure identically. Looking at spec sheets of Nichicon at Mouser, these Soundia's don't look too good.
It looks like I can use two lead capacitors, but will probably need to glue them down for support.Last edited by primetime; 10-01-2016, 04:17 PM.Comment
+1, They are just filter cap for +/- dual supply, one cap has NEGATIVE leg to circuit GND, and another cap has Positive leg to GND.Never stop learning
.4 esr on those is lousy.
bet you have hum issues.View Me
It looks like I can use two lead capacitors, but will probably need to glue them down for support.Comment
Yes, center holes are 10mm apart. I'd prefer to get a 4 legged capacitor if I have a choice since it adds extra anchor given the size of the capacitor and the 15" woofer that will be vibrating it. In fact one leg did break a solder joint.
The sub did have hum among other issues. Four other Soundia caps blown. I figured I'll replace all the Soundias.Last edited by primetime; 10-02-2016, 08:28 PM.Comment
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
I know that these capacitor will not last as long as nichicon capacitor...-
by chth96I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...-
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
- Loading...
