ESR value for 2200uF?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    What's the good value for 2200uF?
    I saw 0.07 ohm on my tester...is it good ?
    thanks
  • mmartell
    • Oct 2013
    • 3189
    Re: ESR value for 2200uF?
    According to tables the Esr generally goes down as capacitance rises so sounds about right
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      you really need to download the manufactures data sheet for that particular capacitor it will then tell you the correct esr
        • 31294
        what make & series cap is it?
        • bianchi77
          • Jun 2016
          • 1121
          Let me have a look, what make and series of it ....
          Is there a standard / normal ESR value tolerance for all capacitors ?
            • 31294
            no.
            every make & series is different.
            • bianchi77
              • Jun 2016
              • 1121
              I see...so I need to see the datasheet for every capacitors to check its ESR....
                • Jul 2011
                • 6070
                I have a Blue ESR Meter and the the cart say that any cap value over 500uf
                The highest value you can have 0.1
                  • 31294
                  and it could still be bad.
                  • bianchi77
                    • Jun 2016
                    • 1121
                    more than 0.1 ohm for larger 500uF ....most likely faulty caps....?
