I have a few ucc kzg 1500uf caps on my old 775 mobo. Are they compatible with nichicon hm?
is nichicon hm compatible with ucc kzg?
Re: is nichicon hm compatible with ucc kzg?
Yes.
Nichicon HM is a direct replacement for Chemicon KZG, especially the 16V 1500 uF 10x20 mm size.
Also, I see your Nichicon HM caps have a H06xx datecodes. That means they were manufactured sometimes in 2006 - which is good, because Nichicon HM and HN with datecodes between 2001-2004 and some from 2005 had problems. 2006 and newer is fine, though. -
2005 was a "transitioning" year for Nichicon HM and HN capacitors. Some caps from 2005 do end up being bad, others are okay. I think week 11 is a pretty early, so those may be more likely to have problems. I'm not an expert on this matter, though (I think Wester547 might know better... let's hope he sees this thread and chimes in.)
Those should be good.Comment
I wouldn't say I know better than anyone else. My standards for "reliable cap" might be a bit more rigorous than some. Those Nichicon HNs don't have vents so I think they would be more likely to quietly dry out through the bottom rubber bung. I don't see a 680uF 4V value in the datasheet (they could be a custom order). They are in parallel with polymers so you might get away with leaving them. But if you really want to replace them, it would be interesting to see what the rubber bung actually looks like (hopefully not a concentric bung!) so as to verify the genuineness of those capacitors.
Everyone's standard for a reliable cap is bound to be different, especially since everyone has different experiences with different brands and series. Some people haven't had a problem with KZGs or Teapo, others wouldn't chance "relying" on them if their lives depended on it. The real problem with bad caps is bad QC. That's how people can have so many inconsistent experiences with them. At the very least, though, replace those KZGs. Even capacitors on the input of a buck regulator can cause irrevocable damage to whatever chip that DC-DC converter is powering if they go bad (the CPU in this case).Last edited by Wester547; 08-25-2016, 10:01 PM.Comment
As you know (I'm sure I mentioned it more than once), I've had a router die from bad caps on its buck regulator input. And that's just once instance off the top of my head. Had a few other similar cases in other devices.
I agree 100%.
Well, this is less likely to happen to the CPU VRM, since it usually has a more advanced chip than your typical PWM controller. But I agree that capacitors on the input of a buck regulator indeed should not be deemed less important than the output.
The risk with capacitors on a buck regulator going bad is plummeted capacitance which ultimately results in fried chips (by way of voltage spikes) since the energy released from the inductors has nowhere to go (or rather, there's nothing standing between that energy and the ICs).Last edited by Wester547; 08-27-2016, 09:56 PM.Comment
Yes, that's a good way to put it.
Had a Core 2 Duo withstand MOSFETs shorting on a Intel DG33TL-equivalent board multiple times. One of the phase's MOSFET drivers must have been bad (I say *must*, because they all appeared okay on my multimeter). But unfortunately, it cost me a lot of MOSFETs to realize this. Each time a FET shorted, the PSU would enter into short-circuit protection. Surprisingly, the CPU is still alive and working. I guess perhaps this is because CPUs have a low static resistance, thus keeping the power load on the CPU VRM sufficiently high regardless of CPU load. So there's always somewhere for the energy in the inductors to go, even if the caps went bad. RAM, on the other hand, ofter doesn't use much power and doesn't support much of a voltage variation. So that could well be the reason why RAM is more likely to die from a bad FET on the buck regulator circuit.Comment
Originally posted by momakaI guess perhaps this is because CPUs have a low static resistance, thus keeping the power load on the CPU VRM sufficiently high regardless of CPU load. So there's always somewhere for the energy in the inductors to go, even if the caps went bad.I suppose this is the one good thing about high TDP CPUs... assuming of course those high TDP CPUs are worth anything.
*cough*prescott*cough*
It started freezing today so i decided to finally recap it. Pulled those li'l suckers out and ONLY 1 was good on esr meter. Other 3 showed 800uf instead of 1500uf and 0.5 ohm resistance. After recap it runs like charm. Can u tell which one is good and which one is bad? (pics 2 and 3 also sorry for bad focus on pic 3). Pic 5 hn from the bottom.Last edited by nick122; 08-31-2016, 11:56 AM.Comment
That last picture looks like a Panasonic capacitor from the bottom, not a Nichicon. A Panasonic FJ, to be meticulous. Three of the four KZGs look like they have slightly bulging bungs (picture 4). Glad to hear you fixed it.Comment
Nice! Looks like another motherboard saved here.
Keep us posted if that really was the solution to your problem (longterm)... although with those KZGs reading nearly half their capacitance and high on ESR, I wouldn't be surprised if they have failed and caused the problems you were having.
That said, I am curious to see if these failed KZGs caps will pass the spark test - that is, charge each of the caps with a 12-15V source / power supply. Then remove the caps from the source and press both of the cap's terminals on a metal surface. If you see/hear a spark, they are either still working on not completely bad yet. But if you don't see or hear a spark, they are definitely gone. I can tell you from personal experiments that a 16V 1500 uF low ESR cap will definitely produce visible and audible sparks (but nothing loud, though).
FYI, this post was brought to you by a 2.8 GHz P4 Prescott HT.
Although the single-core Prescott is rated for 89 Watts TDP, its maximum power consumption is only 100 Watts, which isn't that terrible. There are modern CPUs out there nowadays that are much more power-hungry than that - even more than the Pentium D dual-core CPUs (i.e. 2x Prescott dies). And modern GPUs? Don't even get me started on that!Last edited by momaka; 08-31-2016, 06:53 PM.Comment
That being said, you have a point. If you go look at the UCC (not NCC) datasheets for their general purpose capacitors (85˚C or 105˚C general purpose), they actually list the highest acceptable ESR values at 120Hz and 20˚C. According to UCC, the highest acceptable ESR value for a 5x11 0.1uF 50V SMG is a whooping 1,989.0Ω ESR.
Hey, don't be dissin' the Prescotts!FYI, this post was brought to you by a 2.8 GHz P4 Prescott HT.
Although the single-core Prescott is rated for 89 Watts TDP, its maximum power consumption is only 100 Watts, which isn't that terrible. There are modern CPUs out there nowadays that are much more power-hungry than that - even more than the Pentium D dual-core CPUs (i.e. 2x Prescott dies). And modern GPUs? Don't even get me started on that!Comment
I'll try to measure mine tomorrow and see what I get.
Might as well substitute a resistor then.
I can understand using electrolytic caps for 1 uF and above. But below that, I'd just go with polypropylene, polyester, or some other poly- cap and be done with it.
What worries me more is the difference in power consumption we see nowadays on modern CPUs: they can go from just a few Watts of power in idle mode to well over a 100 Watts during full load. That IMO is bound to create a lot of thermal stress on the die, no matter what heatsink you are using. In comparison, a good ol' Prescott doesn't have that great of a difference between idle and full load power consumption. As such, the CPU die isn't that stressed (sure it's running hot all of the time, but that's better than constant thermal cycling). So don't be surprised if you see a Pentium 4 CPU still chugging along 10-20 years from now.Last edited by momaka; 08-31-2016, 10:38 PM.Comment
Whaaaaat!!!Might as well substitute a resistor then.
For CPUs, I think up to 100-120 Watts is okay and not that hard to cool. Anything above that, though, will require a big heatsink with several heatpipes.
What worries me a bit about hot-running Pentium 4 CPUs is the fact that they (Intel) specified the usage of BGA solder balls for the actual socket-to-motherboard connection. So even though the CPU itself was PGA, the connection to the PCB itself was BGA. With such hot running Pentium 4 CPUs swinging between room temperature and high temperatures (thermal cycles between the stabilized operating temperature and storage time), it was bound to cause a BGA-related failure over time. I think Kaboom had a Pentium 4 Prescott with this issue, with the crappy retention brackets on the Socket 478 heatsink exacerbating the BGA failure. I understand that all modern motherboards attach the socket to the motherboard by way of the BGA package, but I think something else will probably give out before that does... like a hot running BGA RoHS chipset.
For me, the best of the Pentium 4s was the Northwood. They didn't overclock well ("Northwood Sudden Death Syndrome") but they ran very cool and for the time were good performers.Last edited by Wester547; 09-01-2016, 12:04 AM.Comment
. Under load its usually between 65 and 70c and thats pretty hot for a cpu. PreshotComment
AMD Athlon XP CPUs also have very little difference between idle and load. But they don't run that cool, though, due to higher TDP.
Also, there are a few motherboards out there with thru-hole CPUs sockets (like my ECS P4VXA-SD2+).
Now what is worrisome about those BGA sockets is that they get quite abused by the crappy design of Intel's heatsink retention mechanism - it often put so much pressure on the motherboards that they warp quite badly under the CPU socket. What I do with those is typically just sand/grind down the lobes on the plastic tension handles. That way the heatsink isn't so tight anymore.
You're much more likely to see the chipset BGA fail than the CPU socket BGA.
Originally posted by nick122Absolutely. That mobo ^ is currently running with p4 670 3.6 ghz prescott cpu. I cant get it under 46c even in bios
Well, I only had some bulged 6.3V 3300 uF KZG caps to test, and from those, one of them read 150 Ohms on my transistor tester's ESR function. But I think 150 Ohms is the max ESR that the transistor tester can measure anyways, because I tried a bunch of failed Sacon FZ caps, and those also appeared with the same exact ESR of 150 Ohms. When I tested these caps with the auto-test/detect feature on the transistor tester, the transistor tester couldn't even decide what kind of parts they were, often showing "No, unknown, or damaged part". So there is actually a possibility that these caps were open-circuit. But from the 10 or so KZGs I tested, only one showed that 150-Ohm ESR on the trans. tester. The other ones had anywhere between 1 and 4 Ohms ESR and 1/5 to 1/2 of the printed capacitance.
The electrolyte must be all but gone and/or dried up as it turned from liquid to gas. I would guess that they are completely open (infinite resistance). I wonder how hot those KZGs ran. Then again, the 3300uF 6.3V and 11.5mm high 820uF 6.3V KZGs seem to be the worst of them.
It would be interesting to see how high ESR KZGs could become without going completely open.
Yeah, Pentium 3 CPUs are wonderful.
Well, not really, because even if the CPU runs hot, the thermal contact between the CPU pins and the CPU socket isn't that great.
Also, there are a few motherboards out there with thru-hole CPUs sockets (like my ECS P4VXA-SD2+).Comment
by DrewPhillipsHello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...-
Channel: General Capacitor Questions & Issues
by nick3092I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
by NotEnoughHi everyone,
I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
What I've Tried So Far:- Reseated the cables.
- Reinstalled AWCC and AlienFX services.
- Attempted BIOS downgrade but no improvement.
- Inspected ribbon cables for damage.
- Explored the possibility of BIOS or
by buromI found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have... -
by chth96A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
https://www.badcaps.net/forum/troubl...e-been-blew-up
and I finally fixed this retro game console by soldering varistor and glass fuse.
But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
I have spare console...-
- Loading...
