I recall YT used to have an option for switching between HTML5 and Flash but they axed it 1 1/2 years ago. I actually tried going back to Firefox 3.6, only to find that Flash was not accessible for me on YT until I used the add-on.
Anyways, I'm getting way off-topic here. The point is, you DO need at least a dual-core CPU nowadays to browse comfortably anywhere.
Or good copper layout on the board.
The P5GC-MX I have uses only 2 FETs per phase (yes, just two), 3-phases total. No heatsinks. Yet, that motherboard is actually designed to handle every Netburts, including the hottest of the hottest Pentium D and even Pentium Extreme Edition chips, IIRC. The VRM does run warm, but nothing is scorching hot. Rather just the entire board gets warm. ASUS actually designed the VRM pretty well there.
But I DO use "junk" thermal compound
... or at least some no-name eBay stuff. It's very runny, but has worked great on everything I've applied it on so far. Doesn't dry out either.
That's not to say that every cheap no-name compound is good. Early in the days of eBay, I tried this brand called "Spectra Cool" - now that was a JUNK thermal compound. It felt like applying chalk and water, and behaved much the same way after a few days of use. Even the unused compound in the tiny syringe got dried up after about a year. Whereas the compound I am using now is maybe 3-4 years old and still fine.
... or at least some no-name eBay stuff. It's very runny, but has worked great on everything I've applied it on so far. Doesn't dry out either.That's not to say that every cheap no-name compound is good. Early in the days of eBay, I tried this brand called "Spectra Cool" - now that was a JUNK thermal compound. It felt like applying chalk and water, and behaved much the same way after a few days of use. Even the unused compound in the tiny syringe got dried up after about a year. Whereas the compound I am using now is maybe 3-4 years old and still fine.
Not really. BGA is actually not that hard to work/rework. In fact, you don't need one of those rework machines at all. Just a temperature probe or two, and something powerful enough to heat the bottom of the board. Gas stove/burner is perfect. If you got hot air for the top, you are all set.
A thru-hole CPU socket would be much harder to rework, IMO, because after you remove the socket, then you will need to clean all of the holes for the new one. And I think that's where it can get tricky.
Actually mostly CapXon and Sacon FZ. Teapo comes in a distant third and probably fighting for that spot with Fuhjyyu and Chemicon KZG.
Then again, everyone's junk bin will be dominated depending on what equipment they get to recap. If you do a lot of power supplies, you're bound to be full of Teapo and CapXon. With motherboards, it would probably be Chemicon KZG.
Fuhjyyu dominates your junk bin? I thought you had a love affair with them!
...Joking, of course. Don't hurt me.
Well, I've also seen thru-hole socket 775 boards, but they are rare. I think the Jetway 775GT1-LOGE was one of them. Got outbid on the same board on eBay.
No free-standing FETs/diodes on the P4VXASD2+. All TO-263 parts are soldered to the board properly.
I don't know about the mag-amp typically used on the 3.3V rail, but I do know that in forward converter topologies, one half of each output rectifier is used as a free-wheeling diode for the output inductor.
And what are you saying about the +3.3V magamp? That there is no freewheeling diode required for it in a forward converter?
You're right, it is much more eventful than watching and LCD monitor power ON/OFF.
My little nephew (4 yr old) is always a bit terrified and amazed at the same time when one of my CRT monitors turns ON, especially when I do it in the dark and you can see all of the arcs on the tube as it charges up. He also finds the static noise heard after the CRT turns off very interesting as well.
When he grows up a little, hopefully I can get him interested in building his own computer... and by that I mean a proper desktop. Maybe with a CRT too
. I feel sorry for him right now for only having a tablet to play with at home. These things are absolutely terrible and so limited in anything you can do. Not to mention that the kids constantly get bombarded with advertisements, whether it's watching YouTube or playing a "free" game, or whatever else they do.
And yes, LCDs are boooooooooooring in comparison to CRTs.
I class Teapo right down with the likes of Hermei, Fuhjyyu, and CapXon, honestly. That board powering its CPU from +5V might be why it uses a through-hole socket instead of a BGA socket. I say that because Intel specified the BGA socket after the advent of +12V powered CPUs.
