Replacing 3300uF with 2200uF ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Can I replace 3300uF Caps on my mobo with 2200uF ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Replacing 3300uF with 2200uF ?
    No. Always use the same VLESR type if not polymers.
    • bianchi77
      • Jun 2016
      • 1121
      ok, how about 4700uF ? I can't find 3300 in my box...
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        caps have a ±20% tolerance so the caps u replace must be within a ±20% range of the original value or else it could likely cause problems with the circuit.
        • mockingbird
          • Dec 2008
          • 5488
          If it's just a DC output filter then I would personally go for the 4700uF...
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            Originally posted by mockingbird
            if it's just a dc output filter then i would personally go for the 4700uf...
            x2
            • Behemot
              • 4845
              • CZ
              That PC motherboard or what?
              • bianchi77
                • Jun 2016
                • 1121
                Yes it's PC motherboard
                • Behemot
                  • 4845
                  • CZ
                  That may be OK if the new caps have much lower ESR/higher ripple current. So for example replacing something similar to Rubycon MBZ with MFZ/MCZ.
                  I seriously doubt those 4700uF caps are ultra-low ESR in the first place. I only know old low-ESR caps used in the PIII-early Athlon XP era. Those were the best at that time so they put it into VRM. Today they are only in the low-ESR range. Better list what you got there and what motherboard it is.
                  • bianchi77
                    • Jun 2016
                    • 1121
                    I was thinking, making a cable and connect it to the board, because I don't have the exact size...but in the other hand it looks ugly and will affect the performance because of the wire....
                    I bought the right capacitor already, I'm waiting it's being sent now..
                    • Behemot
                      • 4845
                      • CZ
                      Once again, list what you got and what motherboard it is.
                      • Stefan Payne
                        • 1267
                        And we do NOT talk about the series, voltage and capacitance.
                        Those values are, sometimes, utterly unimportant, what's really important are the other values of the cap!
                        And there are things like ESR, the ripple current the cap can endure and some other things like lifetime and so on.
                        So if you would replace a low ESR 3300uF cap with a general purpose 4700uF cap, the cap may pop pretty quickly and other bad things may happen.
                        So please state the name and the series of the caps!
                        And sometimes in a CPU VRM, it can be better to replace the caps with 470uF or something like that - but not wet electroyltic caps but polymer caps instead...
                        • competition
                          Replacing capacitors in Evga PSU
                          by competition
                          I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
                          11-14-2025, 11:12 AM
                        • ajdrenter
                          Picking caps for Antec SU-380
                          by ajdrenter
                          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                          https://www.badcaps.net/forum/showthread.php?t=14159
                          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                          05-13-2023, 10:40 AM
                        • ChaosLegionnaire
                          by ChaosLegionnaire
                          09-13-2022, 09:02 AM
                        • worldofskin
                          30V 3A Powersupply - regulating only to 8V
                          by worldofskin
                          Hey guys! i build a 30V 3A powersupply. My friend blown it... He connected cables to the wrong connectors. I changed the op amps, shorted zener diode and a 9014. Now the powersupply works again but only to 6V. When i measured the caps they looked in spec. But after i connected 2200uF cap on the main power rail parallel to the C1 - 3300uf one - output voltage is now regulatable to 8v. Any idea where to look ? or what to do ? R1 and R2 are getting hot. The input of the transformer is 40V after rectifiers. Its a 24V transformer on 230V mains voltage....
                          02-02-2024, 08:29 AM
                        • Oldschool297
                          RELAND SUN 6.3v 3300uf Low or High ESR?
                          by Oldschool297
                          I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
                          https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
                          08-14-2023, 04:32 AM
