ABIT KG7 with bad caps?
  • damtech
    • Feb 2005
    • 6
    I'm new in this forum... I'm 17 and I come from Italy.
    This site really attract me because I have a problem with an ABIT KG 7 RAID mobo... The system always POSTs and NO memory error are reported. When I start Windows 2000 Advanced Server setup all works fine, only one CRC error during file copy 5 months ago. (I have reinstalled yesterday and no errors during "blue screen" setup). After installing OS, I got many error when installing SP4, both from SCSI and ATA CDROM drives (System drive is on highpoint HPT370 RAID controller,i've tried connecting drive to onboard 686b' controller but nothing changes). I can't install Nero Burning ROM because during file extraction I recieve many CRC errors.Also copying installation files on harddrives (tried each drive) and unpacking with WinRAR causes CRC errors. BTW the system in stable, only one BSOD during these 5 months; only CRC errors during massive DMA transfers between all interfaces (both SCSI controllers, ATA RAID, onboard VIA IDE). One day I've tried to replace Duron with an Athlon XP 2000 but the system hangs during Windows startup with a BSOD telling "BAD SYSTEM CONFIG FILE" or something similar. So I've tried to reinstall Win2000 but the setup freezes or BSODs. Setting up FSB to 100 MHz instead of XP's 133Mhz solves the problem. I can't achieve 133 Mhz FSB with any processor I've tried (AXP 2000, AXP2400,Thunderbird 1000,unlocked Duron 800). The system POSTs, test successufully the memory (with Quick POST disabled) but Win2000 setup freezes. Can be bad caps? I've also installed VLATENCY patch, I'm running latest mobo bios (DS). Mobo has Rubycon capacitor near 3phase CPU Vcore power supply (both 4700uF and 3300uF caps)
    My system configuration:
    -ATX 350W power supply (can be defective?) (voltages sometimes fluctuate)
    -ABIT KG7-RAID MOBO (2 years old)
    -1x512MB DDR266 cas 2.5 Elixir RAM (I've also tried Twinmos 333, Vdata 400 and Kingmax DDR400 with no changes)
    -Matrox G400 DualHead 32MB (changed with a ATI Rage 128 or Matrox Mystique PCI, no changes)
    -CMedia 8738 PCI audio card (removed no changes)
    -Adaptec AHA2940AU
    -ATTO PCIExpress UL2D LSI dual channel Ultra80 SCSI card
    -3COM 3C905-TX 10/100 MBps NIC PCI
    -Waitec Shuttle CDRW SCSI
    -Plextor 40X CDROM ATA
    -Quantum Fireball SE 4.3GB SCSI
    -4xSeagate 4.3 GB 7200RPM USCSI on ATTO SCSI
    -2xQuantum Fireball EL 5.1GB RAID0 on HPT370A
    Sorry for my english...
    Diego
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    elixir is shit ram. i have seen one fail after some months of use. You have tried a few rams though.
    forget about memory tests during boot, they are mostly useless. check ram in dos using a utility like doc memory from http://www.simmtester.com/ you will want to see no fails at all. Tell us if you get fails.
    open up the psu to check the caps inside the psu
    find another psu which you know is good for better testing. if you buy a new psu, recommend 460W because you have a lot of devices.
    tell us more about all the caps on the board which are 1000uf and higher. Are any looking bad? Tell us the names of the caps as well. Forget about the rubycons they are good.
    • MD Willington
      • Sep 2004
      • 702
      Check the amps on your power supply, you need plenty on the 12V rail with your setup, since you have all them HDD's...you power supply is probably not making it through spinup and the capacity takes a dive.
      Whats the true capacity of your power supply? What I mean by that is not whats written on the side like "400W" I mean what are the amperage (A) specs for each voltage on the side of the power supply for:
      3.3V = ?A
      +5V =?A
      +12V =?A
      +5VSB =?A
      MD
      Ya'll think us folk from the country's real funny-like, dontcha?
      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      • RoadKill
        • Jun 2004
        • 49
        Before you do anything, look at the rest of the board, and see what caps are on it.
        If all is apparently good, replace PSU and see what happens.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          MD : some of the crap that is written on the sides of PSUs is BS. Better to check with a multimeter
          • RoadKill
            • Jun 2004
            • 49
            Originally posted by willawake
            MD : MOST of the crap that is written on the sides of PSUs is BS. Better to check with a multimeter
            Fixed for truth. El-Cheapo PSU manufacturers label their PSU specs at low temps that are unattainable in regular use, and other such tricks to make their PSUs look good.
            Plus they use crap parts which will screw up within no time, which would be okay, if it didn't have the oppurtunity to take out the rest of your system.
            • MD Willington
              • Sep 2004
              • 702
              The sticker WILL give some indication of what you have to work with there...
              Yes the sticker will show the Theoretical operating capacity at room temperature, for a cheap ass supply the rating will really take a dive when the temperature goes up.
              Voltages will give some indication ie the voltage will increase in the power supply as the output tries to push current to the device, so yes you can use a voltmeter to read the voltage and get a picture of what's going on...
              I don't know of many people that are going to cut one of their lines and put each end into an ammeter though...
              MD
              • bushytails
                Moderator
                • Dec 2004
                • 217
                No line cutting involved. DC clamp meters are your friend.
                (mine usually needs to be whacked a couple times to get it to work, but for what I paid for it, quite fine by me...)
                --Randy
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  no cable cutting required or even a clamp multimeter. important to test it under load because when all the hdds spin up you can see the prob.
                  this is not a good howto (no pinouts, doesnt mention amps) but gives some ideas.
                  http://www.driverheaven.net/guides/testingPSU/
                  (noob warning - dont try that unless you have researched and are sure about the pinouts.)
                  i got a antec psu tester which just provides some load and a switch to turn the psu on. i jam the multimeter into that also for general checking outside the comp. i gotta get a clamp multimeter cos it is a lot safer.
                  • damtech
                    • Feb 2005
                    • 6
                    Excuse me
                    Hi guys,
                    excuse me if I have been absent for these months but I have had troubles with the power supply of this computer, a QTEC BigFan PFC 400W... I changed it with an old Enermax I had in the garage and now it works very well even with my A64 3400+ overclocked with 250MHz FSB. I tried changing that cheap ass 350W powersupply but no changes. I changed everything, all components, so I think the problem is on the mobo. Now, with 133MHz no OS starts (DOS also hangs on booting) and with 100MHz I have "data lost" messages very often, compromising Windows registry and making system unusable. I will try to disable Highpoint HPT370A controller but I don't think that it could be the problem. Capacitors are 2 Rubycon e 6 (or 5?) Nichicon for the CPU Power Supply.
                    Thanks for your help.
                    Diego
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      firstly q-tec is not a great psu. if you have similar distribution as us in greece i would recommend a fortron 460w or 550w. you have way too much components for your replacement 350w.
                      from the information you have given it cannot be determined whether you have badcaps. rubycon is an extremely reliable brand. Nichicon is also unless you are unlucky and have the HN(M) or HM(M) series in which a large batch had early failure. other nichicon caps we do not see data of early failure.
                      there should be no crc errors at all. if there are you should reduce the overclock and stop running the components so far out of spec. because in the end it will probably damage the components.
                      your hdds are pretty old, are you sure they are still reliable? why not get a cheap 40gb+ seagate ide and stop messing with these old drives.
                      i think that in your case there are too many variables. find another mobo to test that your other components are good before you blame the mobo
                      • damtech
                        • Feb 2005
                        • 6
                        Re: ABIT KG7 with bad caps?
                        hi,
                        all system components work perfectly... the system is now running with an ASUS A7N8X Deluxe in Dual Channel Mode with no problems of data loss or anything. And at 133x2MHz FSB. All great. Reinstalling ABIT Mobo -> can't boot anything. It was a great mobo, with RAID controller onboard but I decided to take it away.
                        Thankyou for support and sorry for my english.
                        bye
                        damtech
                        • TrumanHW
                          Test ATTO N322 network card ROM on Myllenox NIC
                          by TrumanHW
                          I tried to order the Myllenox model that looked most similar to the ATTO NIC (as the ATTO card [is] a Myllenox NIC with modified ROM). Unfortunately, what looked like (close to) identical board+chip layouts in blurry & stock pictures were slightly different once purchased. Still, as the ATTO has a ROM which lets it get identified by a MacOS ... I wanted to try the ATTO ROM on the Myllenox NIC.
                          Any reason [not] to:
                          1. Back up the Myllenox ROM
                          2. Copy the ATTO ROM
                          3. Write ATTO ROM to Myllenox & test if the NIC is recognized by MacOS?...
                          04-24-2023, 05:48 PM
                        • Foetuss
                          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                          by Foetuss
                          Hi all
                          Hope this is in the correct place.
                          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                          Could use some double checking to see if I'm not doing something stupid .
                          Pictures of the boards are attached.
                          What I will be replacing with what : (planned)
                          Soltek Golden ::
                          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                          01-18-2025, 11:44 AM
                        • ziplock
                          Abit BE6-II motherboard
                          by ziplock
                          Greetings,
                          I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                          I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                          04-20-2025, 02:09 PM
                          ABit IP35 Pro Motherboard Schematic
                          ABit IP35 ProABit IP35 Pro Motherboard Schematic
                          A motherboard based on the Intel P35 Bearlake-P+ RAID chipset....
                          10-31-2024, 02:06 PM
                        • tbalint3
                          Abit ST6-Raid repair
                          by tbalint3
                          Hello All,
                          I am trying to repair an old Abit ST6-R motherboard.
                          The symptoms are the following:
                          I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                          It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                          If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                          09-01-2024, 10:03 AM
