FullCon Capacitors
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    FullCon Capacitors
    What's the story on these?
    Good or Bad?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: FullCon Capacitors
    Why only con them part of the way when you can do a Full Con?
    Yeah, I think those would be bad...
    A man convinced against his will is of the same opinion still.
    • gonzo0815
      • Feb 2006
      • 1600
      I would not trust any capacitor with "con" in their names. It is too obvious .
      • Scenic
        o.O
        • Sep 2007
        • 2642
        Rubycon, Nichicon, United Chemi-Con, Sanyo OS-CON ...
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
        • slybunda
          AA and AAA battery charger capacitors?
          by slybunda
          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
          it has inside:
          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
          2 x 470uf 16v LZ105c branded as G.Luxon
          not heard of these brands are they any good?
          iv attached photos of the charger and the board inside for an idea on the type of...
          12-24-2023, 04:41 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • Cama
          Solar Inverter - SMH-II - 2 missing capacitors
          by Cama
          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
          My model is : EASUN SMH-II 7 KW
          Mother Board : P/N 18947-002401250250
          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
          Thank you...
          09-12-2025, 02:50 AM
        • Ady2017
          Are there any datasheets available for Elna RJG capacitors?
          by Ady2017
          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
          05-25-2025, 02:19 PM
