capacitor replacement in Camaro
  • avidgamr
    • Nov 2013
    • 16
    Re: capacitor replacement in Camaro
    On a side note, would you guys use a solder sucker to attempt to pull up the solder from the IC pins or use a desolder braid or? I tried years ago to remove an IC and ended up ruining it from too much heat. Kinda leary of doing this...
      • 31259
      first you need to add lots of fresh solder to get through the corrosive crap.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the ones i got in for this all lived.watch out for eaten traces.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5081
          • New Zealand
          I would use a vacuum desoldering gun on it myself, but I'm guessing you don't have one of those.
          Given the low mass of the tracks\pads on that board though, a standard solder sucker or wick should work - provided you have the technique down.
          If you have had problems doing this kind of thing before though, I suggest you get some old boards from the dump or something and practice on them. Watch Youtube videos etc on it and get ideas.
          In all cases when desoldering old parts like this: add fresh solder first!
          -David VanHorn
            I would cut the IC legs with good pair of diag (no need to save the IC but rather save the board than the used IC), you cut all the legs on one side of the IC then you bend the IC body back and forth to break the other legs of the IC (the board is double sided so you are not going to damage the pads), after that you can remove each pin off the board.
              • 31259
              WTF - we cant ID the i.c. to replace it!!!
              • Agent24
                I see dead caps
                • Oct 2007
                • 5081
                • New Zealand
                #27
                Good method for removal but it's not suitable here. I don't think the IC is faulty, just the capacitor and possibly corroded trace(s).
                He doesn't have a new IC to replace it with, and like stj said, I don't think anyone even knows what the IC is.
                -David VanHorn
                  • 31259
                  1% chance it's an OPA2743 op-amp
                    WTF indeed. I am just telling how I remove bad IC and save the board, especially multiple pins on double side board since OP is so worried about damaging the board if he needs to remove the ICs.
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • the_rem
                      Unknown transformer : how to find a good replacement part ?
                      by the_rem
                      Hello guys,
                      I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                      I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                      04-23-2025, 01:48 AM
                    • ezenia
                      PS4 controller left stick potentiometer replacement issue
                      by ezenia
                      Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                      So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                      I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                      09-30-2023, 02:19 PM
                    • boosti45
                      Macbook pro logic board replacement parts quesion
                      by boosti45
                      i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                      08-21-2024, 05:23 AM
                    • r2digital
                      klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                      by r2digital
                      I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                      04-18-2024, 03:50 PM
