hi all im currently building an esr meter will this be able to check the esr of the caps on my laptop board or would a oscilloscope with a signal generator be a better choice the esr meter im building is the one posted on here under cheaper esr meter
ceramic caps testing
Re: ceramic caps testing
Your title is testing ceramic capacitors. Is this what you are trying to measure?
Ceramics have very low ESR and are very hard to test/measure. Low ESR electrolytics are hard enough. eg if a good electro has 10 milliohm ESR this will require 1 amp to produce a 10 millivolt signal.
This current level would be unusual from a signal generator. Normally this is achieved with pulsed currents in low ESR meters.
Ceramics. Well, typically it is not worth trying, their ESR is so low and they do not degrade like electros and are often low cost to replace.Gigabyte EP45-DS3L Ultra Reliable (Power saver)
160Gb WD SATAII Server grade
Nvidia 8500GT 256Mb
Samsung 18x DVD writer
33 way card reader
Windows XP Pro SP3
17" Benq FP737s LCD monitor
HP Officejet Pro K5300 with refillable tanks -
thanks for the reply all im doing is trying to get my old laptop working playing around really with it as it facinates me to see all those resistors/caps/diodes so as the caps are hard to diagnose i was trying to build something that would check them to see if they are okComment
laptops can be can of worms.
I suppose depending on make model and fault there are common area's of failure.
but as above re ceramic caps
ESR for Electrolytic type caps and then were ESR is more liable to count such as SM-PSU and MB VRM circuts
(on these forums anyway but there are other circuits an devices its good to have one for)
re the Lappy
if you post make model and fault description someone here may be able to tell you your most likely trouble spots.
me, I don't work on them or very rarely anyway
heat is the enemy of these things and power problems or high heat area's
(such as around CPU) I suppose are probably going to be you first ports of call.
But there are some ..well lets say design issues or manufacturing issues that might narrow this
Like one Brand (model(s) ) they was prone to lots dry joints.
So you might be lucky and have a well know fixable issue.
welcome
Cheers
You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by momakaThis one should make @Pentium4 smile
(if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
Macron Power Technology Co. LTD.
Let’s look at the PSU itself.
The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of... -
Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...6 Photos-
05-05-2024, 02:04 PM -
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
- Loading...
