Mosfet removal
    Mosfet removal
    Does anyone know how to remove motherboard mosfets i tried soldering iron but it is impossible and almost caused damage to the board.Thanks in advance
    Re: Mosfet removal
    I lift and bend up the little legs first and then work on the heat sink part.
    - For the heatsink side.
    I use something for a grabber to latch on to the MOSFET.
    Can't do much pressure in grabbing or you might crack the casing. Make a mess.
    Solder iron in one hand applied to the heatsink.
    Grabber in the other hand.
    When it comes free lift.
    Grabber could be tweezers, mini-needlenose, hemostat.
    Other folks may have a better way.
    Mann-Made Global Warming.
    - Dr Seuss
      Re: Mosfet removal
      Yes.I was searching for mosfet removal on google and found some info .Someone said he used hot air gun. that would be interesting.The problem is what kind of what temperaure etc?
        Re: Mosfet removal
        I don't do it that way so I don't know.
        Seems that might melt loose nearby SMD parts though.
        Be careful.
        - Dr Seuss
          Re: Mosfet removal
          Use plenty of solder too - lots on the tip of the iron and lots on the heatsink tab. Then apply lots of heat, wait, wait a bit more and it'll come off.
          Remember the board will get hot though, so give it a few minutes to cool down before moving onto the next mosfet.
          Hot air works if you have a small nozzle and lots of control over heat/air flow, but I always find it easier with a soldering iron.
            Re: Mosfet removal
            A broad hot air gun will cause problems with surround components.
            It is important to use a high powered soldering iron 50 watts or more. The heat energy is removed fast by the MOSFET heatsinking. Use plenty of fluxed solder.
            160Gb WD SATAII Server grade
            Nvidia 8500GT 256Mb
            Samsung 18x DVD writer
            33 way card reader
            Windows XP Pro SP3
            17" Benq FP737s LCD monitor
              Re: Mosfet removal
              My method is...
              (1) lift up and bend the 2 little legs as mentioned by PCBONEZ. or cut it off.
              (2) heat up the the MOSFET area using hair dryer for 10~20 seconds.
              (3) use high power soldering iron to remove the transistor.
              Hot air gun is a better choice. But do not set too high air-flow as it may damage the surrounding components.
              It depends on the MOSFET package. DPAK is easier to work with as compared to D2PAK.
                Re: Mosfet removal
                Hmmm,
                Hot air for a pre-heat...
                That's a really good idea Mr Brian.
                - Dr Seuss
                  Re: Mosfet removal
                  Remember heat kills electrolytics and if a hot air gun was raising temp to 260C it would be bad news for cap.
                  Nvidia 8500GT 256Mb
                  33 way card reader
                  Windows XP Pro SP3
                    Re: Mosfet removal
                    I did a reply to this more detail but lost it cause FF went west on a page I was trying to open
                    I agree with the above posts on the pro and cons
                    the biggest problem is getting a lot of heat into the tab to melt the solder but without exposing everything else to a lot of heat.
                    pre heating isn't a bad idea its just controlling it
                    Still I don't recommend blasting away with something like a paint stripper....maybe a hair dryer as above
                    (the idea being to warm up the component and immediate area)
                    I suggest you use a flat broad type soldering iron tip (chisel not a conical tip)
                    Make sure its clean and put some solder on it then put it on the tab adding a bit more solder
                    the extra solder will help with heat transfer
                    (and thats what your after good thermal contact to conduct the heat and melt the solder)
                    Then use tweezers or small pliers to grip the body, as soon as you feel it float free lift it off
                    If you are sure the MOSFET is dead I'd just cut the legs near the case with nippy cutters
                    (being careful not to cut into the PCB)
                    If you are wanting to remove one for testing..."as above" free the legs first before going for the tab.
                    Its easy to remove the legs once they are free of the body with a LOT LESS risk to the solder pads
                    (same thing thought clean tip smidgen of solder to the tip for better heat transfer, you wont need to add extra thought...well if you get the smidgen right)
                    clean up excess with solder wick when component is gone
                    adding extra flux will cause the solder to ball on its self which helps.
                    (I think its a case of too much solder does a bad joint make)
                    There are tools you can get for this type of work, like these here
                    I have used these to remove mosfets,
                    they do make it a little less painful.
                    BUt $$$$
                    So try the above ideas on junk MB's if you got some
                    you should practice on some really...
                    as you say the last thing you want to do is damage the PCB
                    It shouldn't take long to get a feel for it
                    how will heat is conducted to and away will probably determine how long it takes
                    which is why you need a nice hot iron with good thermal inertia
                    (heat sink effect cooling the tip off)
                    HTH
                    Cheers
                      Re: Mosfet removal
                      Small point Starfury. The MOSFET does not need to be removed for testing, just lift the two leads. This will minimise temperature stress if the device is still good.
                      Nvidia 8500GT 256Mb
                      33 way card reader
                      Windows XP Pro SP3
                        Re: Mosfet removal
                        yeah True ...thinking cap wasn't on
                        thinking more of discrete size transistors when it was easier to remove them for more through testing.
                        Mosfets tend to fail in a more catastrophic way. like short and burn the place down ok maybe not that bad but I've known them to claim quite a few PCB's in my time (not sure on MB side of things thought)
                        Thanks davmax for the correction there
                        Cheers
