When to Choose ZL vs. MCZ
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: When to Choose ZL vs. MCZ
    >>> it feasable that these 15 electrolytics would boil due to overheating, and not one other single component in the system fail? <<<
    Absolutely!
    Other parts don't have to deal with pressure effects from liquids, gases, and gases in solution.
    Capacitors are filled with liquid which expands and contracts with temperature even if there is no significant gas present at first.
    Heat them up enough and they are going to pop.
    In fact heating them up -too fast- can do the same thing if there is gas present. Warm them up at expected heat-up rates and some gas goes back into solution countering the effects of the expanding liquid. Heat them up way too fast and the gas can't absorb (get out of the way) fast enough for the expanding liquid. - Pressure spike.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Foxconn is that actual manufacturer for (most if not all) Intel boards and has been for several years. - A little outsourcing fact Intel would like to keep hidden from the public.
      - Dr Seuss
      • starfury1
        • May 2006
        • 1256
        #63
        "brain fart" as Bonez so well puts it.
        Gonzo
        I would just use polymer capacitors in this case, they have superior endurance at high temperature, lower ESR and lower Z and a very high ripple current rating.
        Half the capacitance should be sufficient in case of polymer cap replacement.
        thats the bit I was trying to recall and put in correct terms thanks
        bonez
        it ain't now
        keep us posted KC8
        cheers
        cheers
        You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
        • Big Pope
          Approved Vendor
          • Dec 2005
          • 426
          #64
          Originally posted by kc8adu
          cool!
          i may have 2 of these little desktop blast furnaces coming in as donations.
          i will do one up in your parts and the other in one of the polymers i have.
          I am ready in anytime, just shoot me a PM if you need?
          My SAMXON Capacitors Database HERE!!
          X-CON is a new brand for SAMXON's Polymer Capacitors.
          • leezhihao2020
            TL866-3G programmer,bios chip 25B127DSIG which option should I choose?
            by leezhihao2020
            Hello dear friends,
            I download the software for the programmer T48 TL866-3G
            my HP ProBook 430 G5 2VP86EA with
            motherboard model: DA0X8BMB6F0 rev F and
            BIOS CHIP model: 25B127DSIG BIOS
            is showed there 4 times:
            25B127DSIG @DIP8
            25B127DSIG @SOIC8
            25B127DSIG @WSON8
            25B127DSIG @SOIC16
            So I don't know which version should i choose if I used the test clip cable?
            if I choose the wrong option, can it make damage to the chip or to one of the laptops while I used the test clip cable? because I have no experience in soldering....
            01-14-2023, 09:12 PM
          • fab13
            ps4 power supply resistance out of order, what to choose?
            by fab13
            Hello
            After checking this resistor which gives no value on the ohmmeter on a PS4 SLIM power supply.
            I would like to change it but by which power I can choose it knowing that this resistor is on the primary part that is to say on the 230/400 V side
            Value 16.8 Ohm normally according to color code (See photo)
            1st ring = Brown = 1
            2nd ring Blue = 6
            3rd ring Grey = 8
            4th ring OR Multiplier = x0.1 Ohm
            5th ring Red = +/- 2 %.
            Tolerance of either + or - 0.336 ohms
            Dimension of the resistor Length = 6.4mm,...
            12-08-2022, 04:24 PM
          • bohaboha
            Help Me Choose the Right MAINBOARD
            by bohaboha
            It applies to Mainboard BN41-02751B-000 for Samsung UE70TU6905
            this is what is on stick : HU10 BN94-18627N P09R
            010233092557 0062 2021023
            1465.4-143/1010
            There are several part on Ebay for 55,65 and 70 TV but the number on the Stick label is not quite correct I am very unsure if they fit or even if they are somehow compatible with my unit. Very very grateful for any help
            01-19-2025, 02:05 PM
          • learnmore
            How to choose a substitute mainboard
            by learnmore
            Hello again Community
            Anyone verse on how you go about choosing a substitute mainboard for your TV repair. Like the chap in the video below sometimes a 1:1 replacement board is too expensive and reballing a mainchip(s) maybe outside of your skillset . In the video the poster states one needs to match the replacement board with the SMPS, T-con (if not built in) and panel (and substitute cabling be also be required).
            I'm very interested in choosing a suitable replacement board for any model or make of TV and the general (or detailed if your willing) step this entails....
            03-23-2024, 02:55 AM
          • cheese007
            Input Filter Filling: How to Choose Components?
            by cheese007
            Recently acquired one of those silly Logisys acrylic power supplies and lucked into getting one of the "better" ones (most of an input filter, bridge rectifier instead of 4 diode treatment, OK-sized heatsinks, etc.) and wanted to fill out what I can on the board + get some decent caps on there (especially the primary side since I highly doubt the ones in there are actually 1000uf). My questions are:
            1. How do I know what components to install re: the input filter? It seem to be missing an X cap, a resistor, and a Y cap.
            2. Where can I find a good heatsink for the bridge...
            12-06-2023, 09:59 AM
