ESR, how low is too low?
  • zeus
    • Dec 2007
    • 16
    I got my ESR meter last Friday and have been comparing old lytics with new ones to get an idea on numbers.
    I found a 27yr old ELNA 47uf, 160v, 85c, that measured 0.19 ohms and should be around 1.0 ohm.
    Why is this lytic's ESR so low?
    Is this considered a bad lytic?
  • PeteS in CA
    • Aug 2005
    • 3579
    • USA, Unsure of Planet
    Re: ESR, how low is too low?
    Hmmm ... I'm a little surprised that ESR would be specified for an 85C cap. That 1.0 ohm will be a maximum rating, of course. Two Qs might account for the another part of difference. Is the rated 1.0 ohm ESR at 120Hz? And what is the measurement frequency of you ESR meter? If the rating is at 120Hz and the meter is measuring at 10KHz-100KHz, that would pretty much explain the difference.
    All that said, did you check to see if the cap is shorted?
    PeteS in CA
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      It might also be partially shorted from overheating.
      That's why you check with an ohm meter as well.
      Mann-Made Global Warming.
      - Dr Seuss
      • zeus
        • Dec 2007
        • 16
        Correct PeteS, 85c lytics do not have specified ESR ratings. I got the 1.0 ohm number from a
        chart on the web that said this chart was a "rough guide only". Considering ESR is a
        rather important spec, Why manufactures don't put it on data sheets for all series
        lytics I'll never know. I guess they want end users to reinvent the wheel every week.
        The chart didn't say what freq the ratings were measured.
        My meter only measures at 100KHz.
        This cap does not seem to be shorted.
        What reading should I get for a new 47uF, 160v, 85c lytic cap tested at 100KHz?
        Is there a good reliable ESR chart for GP lytics out on the web?
        Is there a formula I should be using?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          GP lytics are not generally used in applications where ESR matters all that much which is why it's not in the data sheets.
          Or the inverse.
          If ESR matters they don't use GP caps.
          - Dr Seuss
          • zeus
            • Dec 2007
            • 16
            PCBONEZ, I ohmed this ELNA cap and got 19.36 Mohms using a Fluke 289.
            So its not shorted.
            • zeus
              • Dec 2007
              • 16
              Or the inverse.
              I understand that, I'm trying to learn when a GP cap has bad ESR numbers.
              I need to compare good numbers with bad. I found a ELNA 47uF, 160v, 85c
              lytic cap that seems to have an ESR number that is too low (0.19ohms).
              • zeus
                • Dec 2007
                • 16
                Or the inverse.
                So, you're saying GP lytics don't need to be tested for ESR at all?
                How do you properly test a GP lytic to see if it's good or bad then?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I agree that 0.19 ohms sounds wrong but:
                  You have no point of reference.
                  There is no data for it.
                  You can't compare it to other manufacturers or series or caps because they will all be different just as they are in low ESR series and makes.
                  The only way to get a point of reference is to compare it to several ELNA 47uF, 160v, 85c from the exact same series. (Actually any in the same series with the same can size should be nearly the same.)
                  Lacking that, you can test all you want but the numbers don't really mean anything.
                  Also, ESR should go up as caps age, not down.
                  Are you sure that meter is operating properly?
                  - Dr Seuss
                  • PeteS in CA
                    • Aug 2005
                    • 3579
                    using a Fluke 289
                    I have DMM envy.
                    PeteS in CA
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      "DMM envy" ???
                      Is that like ....... oh never mind.
                      - Dr Seuss
                      • PeteS in CA
                        • Aug 2005
                        • 3579
                        Fluke's 289 is their newest high end DMM. Put one of those and a Fluke 199C Scopemeter in a brief case and you practically have a portable engineering lab. Think of it as techno-macho.
                        PeteS in CA
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          No, I meant more like 'probe' envy.
                          - Dr Seuss
                          • zeus
                            • Dec 2007
                            • 16
                            Ok, so I will assume this cap is bad. I guess I'll be testing every old and new lytic cap that crosses
                            my path and log it's measurements to come up with some sort of average to compare to.
                            I received my 289FVF a week and a half ago, and I can't put it down (little kid in a candy store).
                            I did spend the extra $70 for the extra goodies just to see what the Fluke View software was like.
                            I must say the 289 is night and day compared to my 179. I now have some components that test ok,
                            that tested bad on the 179 do to the 289's accuracy. It was often hard to get a 0.27ohm resistor to
                            measure in tolerance with the 179.
                            I never thought I'd spend $600 for a DMM, but hey, I sold some crap on Craig's List, and walla,
                            I'm in DMM heaven. LOL!
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Now that there is a nice meter.
                              NICE.
                              - Dr Seuss
                              • willawake
                                Super Modulator
                                • Nov 2003
                                • 8457
                                • Greece
                                damn you have more pens than me also
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Back to the original question.
                                  You have to look at what the cap is doing in the circuit.
                                  Also have to consider that a cap's ESR changes with frequency. The data tables only show ESR at one frequency. You have to get into the graphs and/or math to figure it out at other frequencies.
                                  If it's being used to pass ripple out of a DC circuit as on a motherboard then the lower ESR is at the expected ripple frequency the better off you are.
                                  If it's being used to tune something to some frequency then the ESR at 'some' frequency may be critical to keeping the overall circuit working in spec but I think ESR matters much more as the frequency goes up into the GHz and higher ranges. I don't recall ESR ever coming up when I went through Navy 'radio school' as a precursor to other electronics training. (But that was 27 years ago too. Old technology and old memory.)
                                  - Dr Seuss
                                  • chth96
                                    Is it possible to test small ceramic disc capacitor with analogue meter?
                                    by chth96
                                    I read EBOOK of Testing Electronic Component and found that
                                    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                    Is it really possible to test small ceramic disc capacitor with analogue...
                                    03-09-2024, 10:03 PM
                                    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                    by sam_sam_sam
                                    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                    12-31-2023, 06:04 AM
                                  • jorpec
                                    Changing the scale of an analog meter
                                    by jorpec
                                    Hi
                                    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                    I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                    Thnaks
                                    01-23-2023, 10:37 AM
                                    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                    by sam_sam_sam
                                    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                    12-14-2023, 07:45 PM
                                  • Ady2017
                                    Are there any datasheets available for Elna RJG capacitors?
                                    by Ady2017
                                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                    05-25-2025, 02:19 PM
