Capacitor tester
  • Ice203
    • May 2015
    • 99
    • Uk
    Capacitor tester
    I'm looking for something to test TV capacitor. Any suggestions
  • Kvicala_R
    • May 2015
    • 6
    • Czech Republic
    Re: Capacitor tester
    I'm using for few years this one - its perfect because you don't need to take CAP out of connection http://zajic.cz/esr/esr.htm
    I have seen similar here: http://zl2pd.com/ESRmeter.html
    but I haven't tested it...
      • 31289
      testing caps that are fitted is not reliable, the tester can be confused by other parts.
      also, the cap needs to be discharged first to avoid damaging the meter.
      • Kvicala_R
        • May 2015
        • 6
        • Czech Republic
        You are right - but in case you know the topology you are able to judge if the rest of parts will influence or not. These two tester I mentioned above are only "survey" testers. I'm using it since 2000 and there is not any better equipment in my workroom during repairing of electronics. I used i for million times... The discharge is needed for EVERY tester - there is only "fuse" as two anti-parallel diods on the inputs (measuring voltage less than 0,7V). For sorting GOOD/BAD is the best I have seen...
        In case you want to compare "values" of some Cap with hi accuracy the disassembling is needed (forming as well)...
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • nubinator
          how can i test individual leds without tester
          by nubinator
          Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
          I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
          10-25-2022, 11:05 PM
