Dell GX270 with bad batch of Rubycons or bad board design?
  • Super Nade
    • Jun 2006
    • 294
    Well, a customer of mine contacted me about yet another GX270 with bad Rubycon MCZ near the VDRAM FET. She is afraid that almost all the stock of these boards are plagued by this. What gives? Bad batch of caps or just poor board design? Once she sends the board, I'm going to replace it with an OSCON SEPC 560uF after measuring the max potential between the legs does not exceed 4V.
    This is the recap I did on one of the boards:
    https://www.badcaps.net/forum/showthread.php?t=4412
    I doubt it is a bad batch because ONLY that particular cap in that particular LOCATION blew up.
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • gdement
    • Jan 2007
    • 690
    Re: Dell GX270 with bad batch of Rubycons or bad board design?
    Are there any unpopulated cap locations in parallel with the one that fails? I'm guessing probably not, or Dell would have started using it. But if there is, it might help relieve some of the stress.
    It would be interesting if somebody (probably with an oscilloscope) could figure out what the problem is with that cap. Maybe excessive ripple or bad voltage spikes or something. I don't have one of those boards but I find it interesting anyway.
    • Super Nade
      • Jun 2006
      • 294
      I'll be getting a few boards to work on, so I'll try to provide some scope shots. Curiously, the boards seem to POST, enter Windows blah blah without any problems?
      Q6700 @ 3.6 GHz
      Zippy GSM-6600P
      Abit IP35Pro
      ATi HD4870
      • gdement
        • Jan 2007
        • 690
        Well, I'm no expert on analyzing such things, I'm just an interested observer. I've never even used an oscilloscope.
        • syclonejim
          • Jan 2006
          • 4
          We have had 75 to 100 GX270 MBs replaced because of the failing capacitors. We are now starting to find replacement motherboards with the Rubycon 6.3v 1800uf MCZs blown. We also have found a few Nichion 1500uf 6.3v HN(M)s blown on these same motherboards. Since the Dell warranty has expired as of 1/31, I have been recapping the failed motherboards. I am starting to wonder if the cooling of the Dell cases are leading to failure of the 105c rated caps.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            and the circuit design, psu etc.
            nice to see you are dealing with it. got any pics of what you are doing?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i put 820@2.5 fujitsu re or ncc psa in all the vrm out and vdimm positions.
              i have been using 2200@6.3 mbz at vdimm in +5
              at vrm in +12 i use sanyo sep or ncc ps 330@16 and fill the 2 empty spots on the killerbee sff board.
              i have never seen the 1800@16 mcz bad in several hundred of these i have rebuilt.
              1 of the vdimm caps fails more often since it is near the(hot)vagp reg.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                how to do it pics
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                • Garret Matt.
                  DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
                  by Garret Matt.
                  I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
                  Thank you in advance for any assistance you can render.
                  Inductor In question. Buzzes like...
                  06-20-2025, 01:21 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
