Are These Capacitors?
  • Nerfinator
    • Feb 2015
    • 56
    I think these are smd capacitors, if they are, am I correct in assuming that they've gone back with the blue stuff on the side or the wet, oily look on top?
    If they are not capacitors, what are they?
    Thank you!
    https://onedrive.live.com/redir?resi...6E024849%21743
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Are These Capacitors?
    Not caps. Iirc they are inductors.
    Follow the white rabbit.
    • Nerfinator
      • Feb 2015
      • 56
      Ok, cool and from the sounds of what an inductor is, I should be able to test it by using a continuity meter on each terminal, if it chirps, it's good, if not, it's bad, right?
        • 30917
        pretty much
        • Agent24
          I see dead caps
          • Oct 2007
          • 4913
          • New Zealand
          Continuity is not the only test for inductors. It will tell you if the inductor is not open-circuit, but it will not always tell you if it's OK.
          Inductors (and transformers) can occasionally fail with a shorted turn which will make them useless but not affect the continuity end-to-end.
          -David VanHorn
          • Nerfinator
            • Feb 2015
            • 56
            Interesting Agent24. Is there any way to visually determine if an inductor has failed? I see some blue coloring on the sides (as per pictured) and the top corner of three of them look oily-wet.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4913
              • New Zealand
              None of them look bad to me. The blue and black stuff is just going to be glue or such holding the two haves together.
              Obvious inductor failures will show as the whole thing clearly burnt up or if a lead has obviously broken off, or the core is smashed.
              Otherwise, internal failures are not obvious. Insulation breakdown causing shorted turns would not typically be visible, unless some arcing occurred to create a burnt area, but even then you likely wouldn't see it unless it was:
              1) An outer winding
              2) The windings had no covering
              SMD Chip inductors failed due to internal breakage\crack may be seen on X-Ray but a continuity test would make more sense!
              -David VanHorn
                Those are the inductors for the high frequency filtering for the output of the Class D power amplifiers IC2703 (YDA164C).
                Are you having sound problem in the TV?
                • Nerfinator
                  • Feb 2015
                  • 56
                  First and formost, thank you all for your input and expertise. As a person that never really did anything with electronics and now diving head first into them, I am continually amazed with how little I know.
                  As for bad sound, no. The photo is of the input control board for a 60" Sharp that sounds like it has a bad LED driver board (panel death). I'm just a rabid dog when it comes to stuff like this and don't want to admit defeat but as I've already replaced the T-Con and power board and I've ordered a new input control board, I think I might have to. It's a customer's TV and it's taking a lot of space in my shop.
                  Thank you all though, I really appreciate it.
                  • dragon3x
                    by dragon3x
                    power on.
                    Here are some examples :
                    switching supply area).
                    than 6.3 V.)
                    03-21-2025, 02:46 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                    After all of...
                    07-13-2024, 08:14 PM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
                  • ctroxtell
                    Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                    by ctroxtell
                    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                    01-03-2025, 08:57 PM
