help me identify a capacitor
  • Laith
    • May 2013
    • 12
    • Jordan
    i would appreciate it if anyone could tell me what is the voltage and capacitance of this cap, this is written on it "330R 560 6RF^",
    a picture is attached.
    thank you very much.
  • selldoor
    Slow Learner
    • 7870
    Re: help me identify a capacitor
    Looks like a teapo/ost/unknown my guess would be 560uf 6.3v
    • mariushm
      • May 2011
      • 3799
      It's a 560uF capacitor. The voltage is most likely 6.3v or 10v because I see the same capacitor used right by the usb header and usb works with 5v.
      It's a polymer capacitor, a good chance it's a nichicon fp-cap (functional polymer) based on the red color (but usually you'd see FP written on it so like selldoor says maybe it's another brand) but any polymer capacitor with that diameter and low esr will work.
      • Laith
        • May 2013
        • 12
        • Jordan
        thanks selldoor, i'll replace it now with 560uf and see what happens.
        these cheap motherboards are pretty popular here in Jordan and they give me a headache.
        • Laith
          • May 2013
          • 12
          • Jordan
          oh thanks mariushm, the 330R got me really confused
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • BlackBurn
            Help to identify a laptop mainboard SMD capacitor LA-9982P
            by BlackBurn
            I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
            Thank You. Stay Safe.
            Chamara...
            11-27-2020, 08:30 AM
          • chth96
            If I replace with inferior capacitor, Is it No harm to other IC components at all?
            by chth96
            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
            I know that these capacitor will not last as long as nichicon capacitor...
            12-22-2023, 04:34 AM
          • chth96
            How can I test non-polarized capacitor?
            by chth96
            I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
            I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
            And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
            I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
            06-02-2024, 07:31 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
