Mixing Panasonic FC/FM/FR ?
  • Greeno
    • Feb 2011
    • 36
    • Scotland
    Hi all
    Just a quick and possibly stupid question:
    I'm re-capping a monitor power supply and I can't get all the values I need in just one of these series - is there any reason I shouldn't mix them?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Mixing Panasonic FC/FM/FR ?
    No and it's ok to mix different makes too.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      No - we often say to do that - you often cant get all values in all series and cant get
      all physical sizes in all series. so often do say use FR FM and FC in that order.
      Best to worse ( but still very good. If you still cant find what you need try Rubycon
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        If you are ordering £5 worth of stuff have a look at CPC - they have free post
          • 31213
          dont forget FK, they are important because they are the smaller ones.
          if you can go all FR & FK you get the longest life.
          • Greeno
            • Feb 2011
            • 36
            • Scotland
            I thought that was probably the case - thanks for the reassurance!
            • mockingbird
              • Dec 2008
              • 5484
              FM is superior in every way to FK. So only use FK if you need a small diameter that doesn't exist in FM/FR, because it is usually significantly more expensive.
              • Andre Gilbert
                by Andre Gilbert
                11-20-2024, 08:52 PM
              • proxneo
                Recapping Sony ICF-SW55 - verifying cap values
                by proxneo
                Dear reader
                I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                At the moment, I have selected replacements based on the following list of values:
                3 x 470uF 10VDC
                3 x 4.7uF 35VDC
                4 x 47uF 50VDC
                8 x 22uF 6.3 VDC
                1 x 220uF 6.3VDC
                5 x 100uF 6.3VDC
                Which...
                06-21-2023, 12:38 AM
              • rashidjafar
                Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                by rashidjafar
                I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                Values for :-
                PC43 : Capacitor [3x1.5mm]
                PL7 : Inductor [2x1mm]
                PC39 : Capacitor [1x0.5mm]
                Any ideas would be appreciated.
                I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                08-07-2025, 05:10 PM
              • AquaMan Ua
                Problem with PANASONIC CF53 laptop after changing BIOS settings
                by AquaMan Ua
                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                05-17-2025, 09:40 AM
              • Kobok
                Different (lower) resistor values on PCB?
                by Kobok
                Dear Alls,
                For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                09-19-2022, 07:30 AM
