I know, I'm recapping obviously bad caps, with a bad brand, but that seems to be the cheapest solution right now. And I know, you're supposed not to take them out of a bad board, but, I did. They look fine, but I know, you can't always tell by looks. But I don't have the time to order them from bc, or money to buy them from mouser (after checking their site, they want 10 for like $80). BS
so anyways, it's been a long time since I did any soldering. Last time was like...10 years ago.
The soldering iron that came with my pc repair kit wasn't hot enough. It's 35W, and it's also on a UL recall list, which made me feel just great
so my dad found his variable temp iron. I eventually got it turned up full way, and it still had problems getting this solder to melt.
So he found this other iron of his (he's been doing electronics since he was young, and worked with them for several years, so he has a ton of stuff). It was hot enough. Apparently this board uses some pretty high temp stuff.
Instead of using a sucker, which didn't really work well ($9 aluminum from radio shack). He suggested I use a wick. The only wick I had, wasn't flux coated. He searched and eventually found some old flux of his.
using flux with the wick seemed to work ok, but it made a mess. I don't really care cause I'm taking them off a dead board, but I don't want this on the board I'm fixing.
it seems the easiest and safest (safest = least amount of time with the tip on the board/cap lead) is just standing the board up vertically (mounted in one way or another so something doesn't slip), and putting the tip on the edge of the cap lead off the board and just pushing down or up on the cap, pulling the lead out when the solder melts. This seems to be the most effective way of taking them out.
I bought the bad board from this guy running a computer shop. Had 12 of the right kind I need (just needed 10). It was $5. They're OST I.Q. :/
it's the only hope these people have of getting this board fixed. These people don't have much money. Ether try to recap it and hope it works, or get a new board, and cause it's a HP with the bios tag, I wouldn't be able to use the Winxp install that came with the computer, and that would be another $90, in addition to $69 for a decent board from newegg.
oh just an fyi to the admin, having the bart moon icon next to the text window, is very distracting :P
Bash
