Capacitor Questions (audio related)
  • mtl777
    • Sep 2007
    Hi, glad to find this forum!
    My questions are not really motherboard-related, but they're about capacitor quality so I hope it's alright to post them here.
    1. I have a Delta 1010 soundcard that has a proliferation of "En" marked caps (the "En" being inside an elipse). Sorry I have no picture, but the color is black with white negative stripe. Do you know who is the manufacturer of these caps? Are they good quality? How do they compare with Panasonic?
    2. What caps would you recommend for power supply filtering/decoupling in a soundcard? I've heard lots of praises for Black Gate caps (Rubycon mfg) but they're too expensive. Are they worth the price? Alternatively, are the Panasonic FC's good enough? Or how about Panasonic FM? Are they better than the FC?
    3. My soundcard uses electrolytics for coupling, which is not their ideal application. Why are electrolytics being used here? Is this because of cost considerations only? Can these be safely replaced with polypropylene caps? If so, what brands would you recommend?
    4. I read that replacing a filter cap with two caps in parallel (each cap half the value of the original and the same voltage rating) will give you the same cap value and voltage rating but with the benefit of lower ESR and higher ripple current rating. Is there any downside to doing this, such as increasing the heat, or is the heat more or less going to be the same?
    5. In general, how long is the shelf life of electrolytics? I have an old unused motherboard that's been in storage for 5 years whose capacitors I'm thinking of salvaging for an audio project. Not worth it?
    Enough for now. I hope there are also audio enthusiasts here who are interested in these things. I would also appreciate if you could point me to a good forum where audio-related applications of capacitors are discussed.
    Your help is greatly appreciated. Thanks in advance!
    Michael
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Capacitor Questions (audio related)
    http://forum.recordingreview.com/showthread.php?t=2261
    • mtl777
      • Sep 2007
      Hey, great info in that thread. Thanks a lot!!
      Michael
      • starfury1
        • May 2006
        • 1256
        Suppose it depends on which side of the fence with black gates....
        not that they wouldn't be (or rather want to be) good quality but probably way over priced
        There was a post around here that said for Audio panasonic FC is the much preferred of the 2
        yeah more caps less ESR (sort of like 2 resistors in parallel without getting into the complexity of ESR)
        but dont think thats the issue with Audio, thinks its the HF frequency response or phase change that gets everybody going on what is or what isn't a good cap for audio...I think?...from memory
        Me, my hearing FU's would probably sound OK
        so not really the person to answer this one
        Haven't had a look at will post link yet
        Cheers
        • 999999999
          • Sep 2006
          • 774
          The difference in performance is not likely to be very noticable on a sound card. Well there is an exception, on very old cards that had power amp chips on them then there was some improvement upgrading the bulk filter caps.
          Sound cards tend to have suitable 'lytics and for the higher frequency some SMD caps near the active part they're meant to decouple, and sometimes a few more SMD sprinkled around the card. Unless the manufacturer was really stingy with a low budget, there is not so much reason to replace the power caps but if you wanted to do it anyway or suspect they were too stingy, use something like a general purpose low-ESR cap, it need not even be very low ESR but since they're commonly available you could use Panasonic FM or FC of a slightly higher uF value, something that still fits in the available space instead of being put on in a funny way.
          It's for cost reduction but also the size factor, that typically the coupling caps need to be around 4.7-10uF and a decent film cap in this value is quite large, prohibitively so in the space available on most sound cards. Yes it would be safe to replace with polypropylene in the same uF value, if they'll fit. No particular brand will matter, choose based on the dimensions most accomodating to where you'd put them - industrial types are fine, they need not be something considered botique. Since the audio output voltage is quite low, choosing the lowest cap voltage rating you can find will result in a smaller cap size.
          Replacing these coupling caps is the largest improvement to be made to the card, the power decoupling is pretty trivial compared to this. However, if you aren't directly powering headphones and have an amp stage of some sort after the card and that amp has input coupling caps, you don't necessarily need to have the output coupling caps on the sound card at all, they can be shorted out. The danger in this is if you forgot you had done it, gave the card to someone else or someone else plugged headphones in while it was like this, it could damage the headphones and the card.
          As important a question is whether there is any upside to doing it. Soundcards are digital chips plus analog with feedback loops, you don't need an idealistic cap filtering scheme to achieve results indistinguishable from stock on any decently designed card. There are no large current changes that would suggest trying to parallel caps and to parallel them with only one space for it, you may end up with longer cap leads. The downside is that it looks ghetto but closely positioned parallel caps aren't likely to cause any resonance so there is no inherant problem from a circuit functionality standpoint, and there was never any heat issue in the first place, and none if you did it. If you really wanted to super-tweak the card just for the sake of doing it, you would put large value film caps in these 'lytics positions. I wrote "film" instead of polypropylene because there isn't enough difference in this purpose to be picky about the type, a smaller (per same uF) mylar 10uF could substitute for a similar value 'lytic, but not a much larger value 'lytic.
          That's not just shelf life, they have been used too. Regardless, a manufacturer rates until the cap falls a certain % below it's spec sheet parameters, but that doesn't necessarily mean the cap has fallen below properties that would exclude it from being acceptible for a sound card. It just isn't a demanding role on a sound card. The caps should be fine on an sound card unless they were quite worn out from use on the motherboard or many years old and dried out. With a decent stable electrolyte, that's well over 10 years.
          However, after sitting with no charge for an extended period of time, they will reform some and after several hours of use will perform better. On a power amp this might be noticable, but on a sound card it is less likely.
          • starfury1
            • May 2006
            • 1256
            Thanks 9's...as always an in depth and well put together reply
            (unlike my disjointed waffle)
            humm now
            "Haven't had a look at will post link yet"..... that sort of didn't read right
            It should have read;
            "I Haven't had a look at the link posted by willawake yet"
            • pkslowk
              Debug Card Error Code and Solution
              by pkslowk
              Sr. Motherboard Debug Error Code Solution
              1 Intel 845 E9 Bios Related Problem
              2 Intel 845 D4 CPU Socket Related problem
              3 Intel 845 37 Bios Related Problem
              4 Intel 845 7C Bios Related Problem
              5 Intel 945GCPE 34 Bios Related Problem
              6 Gigabyte 845 2 Ram Related Problem
              7 IBM Server A6 A7 Ram Mismatch Problem
              8 Asus 845 29 CPU Related Problem
              9 Lenovo I946 97 C-Mos Jumper related
              10 Gigabyte 845 A0 CPU Related Problem
              11 Asrock G31M-VS D7 Bios Related Problem
              12 Compaq 845 BD-70G B0 CPU Socket Related problem...
              01-28-2021, 12:51 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
            • Perry Babin
              Derating of polymer electrolytics
              by Perry Babin
              There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
              If they require derating, why would the manufacturer give them their rated voltage?
              This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
              https://www.mouser.com/datashe...
              10-24-2025, 11:57 AM
            • Perry Babin
              Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
              by Perry Babin
              I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
              This is for the primary side of a switching power supply in a car audio amplifier.
              Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
              10-16-2025, 05:20 AM
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
