Second opinion on replacement caps
  • secular
    • Oct 2014
    • 10
    • canada
    I have a LG l204WTX which doesnt turn on, and has been sitting around for 3 years or so now. Back in the day it would sometimes turn on and function normally just by unplugging/plugging in the power cable. it would continue to work as long as it didnt turn off or go into sleep mode.
    Anyways, its completely dead now (and has been for 3 years), with only a rapid flashing blue/yellow light. I probed around and the 5V rail going to the controller board read at 5vs. The 15v rail however was at 18V. Could be a problem, could just be because the LCD (backlight and data) and VGA/DVI was disconnected and that was the unloaded voltage.
    What I did notice were some bulging caps. The caps are SAMXON GF(M)'s.
    The two that are bulging (and are on the 5v rail) are 16v 1000uf (V8A markings, red arrow),
    the two short ones (on the 15v rail) 680uF 25v (V8A markings, blue arrow),
    and the tall one between the two bulging is 25v 1000uf (V9A markings, yellow arrow) (also connected to the 15v rail)
    I think this is the correct datasheet (found from another post on here)
    I dont see anything about the ESR of the caps, but the ripple is 1.2A and the inductance is 60mOhm.
    Searching digikey I found these and I'm hoping that someone can give me a second opinion on these caps. I think they should work. The height restriction is 23mm at most, the current caps are ~16mm.
    Nichicon HW, data sheet here
    680uf, 25v, 30mOhm, Ripple current 2A
    1000uf, 16V, 30mOhm, Ripple current 2A
    1000uF, 25v, 19mOhm, Ripple current 2.5A
    I'm concerned about the ESR rating of these caps, or rather, the lack of the rating.
    Why does both the Nichicon and the SAMXON have no ESR rating?
    thanks for the help!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Second opinion on replacement caps
    The impedance parameter in the datasheet is ESR.
    --- begin sig file ---
    --- end sig file ---
    • secular
      • Oct 2014
      • 10
      • canada
      Thanks for clearing that up. Any thoughts on the replacement caps? Im concerned about the difference between the 'esr' or inductance rating. The caps I found have half the ESR rating. The SAMXON are designed to be "low impedance caps", therefore I would think that the design of the circuit would be independent of the cap ESR. So maybe lower ESR caps wouldnt affect the circuit?
      I'm having trouble finding caps with similar ESR rating that fit within the height restrictions, and are with the same manufacturer. I suppose having different manufacturer caps in the same circuit wouldnt be a big deal.
      • secular
        • Oct 2014
        • 10
        • canada
        I'm thinking the PW series might be better. The impedance is closer to whats in there now.
        Nichicon PW Datasheet
        680uf, 25v, 52mOhm, 1.22A, 10/20mm
        1000uf, 25v, 38mOhm, 1.66A, 12.5/22mm
        1000uf, 16v, 52mOhm, 1.22A, 10/20mm
        VS
        680uF 25v, 60mOhm, 1.21mA, 10/16mm
        1000uf, 25v, 46mOhm, 1.4mA, 10/20mm
        1000uf,16v, 60mOhm, 1.21mA, 10/16mm
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          VS
          In reverse order, I was going to suggest considering Nichicon's PW series (or UCC/NCC LXZ series; or Panasonic's FC series). As you pointed out in the second post I quoted, the characteristics are more similar. All three vendors' series should be reasonably available and not too expensive.
          Impedance is the vector sum or the capacitive reactance (X(C)), the inductive reactance (X(L), aka ESL), and the Equivalent Series Resistance (= ESR). X(C) and X(L) are like adding a positive and a negative number, partly cancelling each other, but the X(C) of relatively large value electrolytic caps is so tiny that it is not relevant.
          Back in the 70s and into the 80s, with 20KHz-30KHz switch frequencies, ESR was the far more significant part of impedance, so cap manufacturers gave that value in their datasheets. from the 80s onward, switch frequencies greater than 50KHz became common, and ESL became more relevant. So cap manufacturers started specifying impedance rather than ESR.
          ESL is related to the mechanical construction and installation of the caps - the lead length, the length of the foils inside (for a given value/voltage a taller part has shorter foils and slightly lower impedance than the same value/voltage part).
          ESR has to do with the resistances of the leads, the foils, and especially the electrolyte. The electrolyte is not the dielectric. Different low impedance series can easily use the same leads and foils, but what differs from series to series is the conductivity of the electrolyte.
          A lot of people here use "ESR" in discussion, because it's easier to type and/or eplain than "impedance". Then there's OCD technoid lifeforms like me, , who type "impedance", .
          PeteS in CA
          • secular
            • Oct 2014
            • 10
            • canada
            Thank you for explaining that. I ordered the PW series. I'll report back if it fixed the monitor.
            • secular
              • Oct 2014
              • 10
              • canada
              Replacing those two bulging caps fixed it. Thanks for the help!
              • G-Laser
                • Oct 2014
                • 10
                So, I have a few caps that I need to replace on a motherboard. These are OST's..
                The RLG spec doesn't mention the impedance. Using math power (a gene I wasn't gifted with), is there a way to calculate this?
                My plan is to replace these caps with higher quality ones as well as stepping up the voltage rating just to give myself a bit more headroom(IE: 6.3v to 10v). It seems that knowing the impedance would be important but I'm not sure if I should just take a guess and pull the trigger.
                BTW: Caps I need to replace are.
                RLX
                470uf 16v 105c
                RLG
                1000uf, 10v, 105c
                100uf, 16v, 105c
                RLP
                1000uf, 6.3v, 105c
                • secular
                  • Oct 2014
                  • 10
                  • canada
                  choosing a capacitor with a higher voltage rating probably wont make a difference. A reputable manufacturer would make a larger difference (and you said you were doing that). If you look for a capacitor with a higher voltage rating, be careful about the dimensions. You could run into a space issue.
                  As for the impedance rating of the RLG, I cant give you a definitive answer. If you cant find a spec, I would use a cap with similar impedance to one of the other series. I'm guessing here, but the other two series (RLX, RLP) specifically state that they are low impedance. The RLG was probably used to save money as the ESR in that part of the circuit isnt critical.
                  I'm sure someone else can provide more useful information.
                  Side note to the OP.
                  I metered the caps I took out of the circuit board. I thought it was interesting to see just how much capacitance was lost. both caps were suppose to be 1000uf, but read as ~330uf and ~110uf.
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    G-L, the Ost RLG series is a general purpose 105C series. I'd suggest using Nichicon PW, Panasonic FC, or UCC LXZ series parts. As secular said, you shouldn't gain anything by buying higher voltage parts, and you may complicate your task needlessly.
                    PeteS in CA
                    • G-Laser
                      • Oct 2014
                      • 10
                      Thanks!
                      I took your advice and looked up those caps.
                      For the 1000uf/10v/105c, it seems like both the Pan FC and UCC LXZ have a higher ripple than the Nichicon PW and a lower impedance. All are over the 520 ripple of the OST.
                      For the 100uf/16v/105c, it's pretty much a wash.
                      Now, I've read in other posts that a higher ripple is better. Please correct my if I'm wrong.
                      Also, I was to understand that upping the voltage would give the caps a bit more headroom. Since I've confirmed that the caps would fit, are there any other reasons why I shouldn't do that? What are other complications?
                      Any info would help clear up any confusion I might have (AKA: Need to learn more).
                      • Jonny Accelerant
                        Banned
                        • Aug 2014
                        • 205
                        What they told me is that newbs don't really need to worry about ripple, and also from what I've read the Pan FC are older and the Pan FM are a good, multipurpose, "one size fits all" capacitor. The Pan FR series are the newest and presumably the best but I could not find a distributor in the US, as they are "too new". Also, in general I gather that ripple is bad and the less you have the better off you are, but I think the primary quality of the cap you need to think about is how long it lasts and everything else is secondary to that. Someone should correct me if I'm wrong.
                        • G-Laser
                          • Oct 2014
                          • 10
                          LOL. Well, if you're implying that veterans do need to worry about it, I would suspect newbs should worry more. I always worry more about what I don't understand but I suspect you're saying that unless you're creating complex circuits, something newbs aren't doing, they shouldn't worry about it. I'm just concerned since I'm repairing someone else's complex circuit.
                          As far as ripple, I have a very high level understanding of this and not very complete. I was just going by what I read in another thread on this forum.
                          • Jonny Accelerant
                            Banned
                            • Aug 2014
                            • 205
                            The point is that ordering replacement caps does not require a "high-level" understanding of ripple, and how that relates to purchasing replacement caps. It's not a factor for consideration. I would think cap diameter in particular, as well as voltage rating, max temperature etc... would be more a important concern.
                            And I wasn't implying anything about vets; I'm saying that they have said to me that a newb learning how to do basic cap replacement doesn't need to worry about ripple. All circuits are "someone else's complex circuits" when doing cap replacement, and of all the threads that I have read, not once has anyone been advised to choose one capacitor over another due to specific qualities regarding ripple. Almost always the decision is based on how high the voltage is going to get, for how long and how hot the capacitor is going to get. I've never read a thread where any other spec has been sacrificed in order to maximize the performance benefits of one particular capacitor due to it's special characteristics regarding ripple. I have a very low understanding of ripple, but I know enough to know that one you've limited the scope of possibilities to top-quality components, "ripple" as a standalone specification is not important.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Wrong. First of all, ripple should be a concern. You should always make sure your replacement caps match or exceed the ratings of the originals. You don't need to be an expert on it, but to say you don't even need to consider it is not accurate. It is important to at least bear the ratings in mind when choosing replacement parts.
                              Second, there is no such thing as a one series fits all cap. Panny FM and FR do have decent ripple and ESR specs on paper, but sometimes, they can be too low ESR. Changing the ESR considerably can, in some power supplies, upset the feedback circuit.
                              If the original caps had similar specs to Panny FC (like CapXon GL), then the best replacement if a Panny FC
                              • Jonny Accelerant
                                Banned
                                • Aug 2014
                                • 205
                                Originally posted by c_hegge
                                Wrong.
                                Well I'm glad we've got that all cleared up then.
                                • G-Laser
                                  • Oct 2014
                                  • 10
                                  Hehe. It stings but in the end, we're smarter so it's a win.
                                  Learning sometimes hurts
                                  • Almighty1
                                    • Apr 2014
                                    • 222
                                    Im also a newb, just slightly a slightly older newb. LOL. In any case, I recently ordered Panasonic FR series from Digikey.com or rather my first capacitor order ever and I'm sure Mouser.com probably sells it too.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4957
                                      • New Zealand
                                      Yes. If you know the specifications of the original capacitors, you should make sure your replacements make sense.
                                      As the exception, I think the one series fits all concept only applies when the capacitors you're replacing were made by HongKongFlyApartCo or such and no datasheet is available, in which case you have no real choice but to use a middle-of-the-road Low ESR or General Purpose series (this will depend on the circuit in question) from one of the decent brands.
                                      -David VanHorn
                                      • G-Laser
                                        • Oct 2014
                                        • 10
                                        OK, so here is what I found. I'm breaking it up into what I currently need to replace (Have) and what I want to replace it with (Replace). I have stuck to replacement caps as close to the original spec as possible. All bad caps are OST.
                                        Please give me your two cents.
                                        Have: RLX 470uf 16v 105c ( )
                                        Replace: Nichicon HN (https://cdn.badcaps-static.com/pdfs/...cf99a3fb27.pdf)
                                        Have: RLG 1000uf, 10v, 105c (http://www.ost.com.tw/pdf/EC/RLG.pdf)
                                        Replace: Panasonic FC ()
                                        Have: RLG 100uf, 16v, 105c (See spec above)
                                        Replace: Nichicon PW()
                                        Have: RLP 1000uf, 6.3v, 105c ()
                                        Replace: Nichicon HV (https://cdn.badcaps-static.com/pdfs/...f9d746a355.pdf)
                                        Thanks,
                                        • black6host
                                          Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                          by black6host
                                          Good day!
                                          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                          I'm going to replace the caps and I'll be the first...
                                          02-06-2024, 08:22 PM
                                        • rewease
                                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                          by rewease
                                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                          09-17-2023, 12:53 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • crosswinds
                                          Assistance with identifying replacement caps on ASUS P5VDZ-MX
                                          by crosswinds
                                          So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                                          Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                                          Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                                          Its a ASUS P5VDZ-MX board.
                                          I would really appreciate some assistance on what the best replacement caps would be for these:
                                          Panasonic(M)...
                                          04-17-2024, 04:25 PM
                                        • HectoPascal
                                          Replacement caps ok? (smoothing caps, PSU heating controller)
                                          by HectoPascal
                                          Hallo,
                                          i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
                                          SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
                                          SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
                                          I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
                                          Nichicon should be 'VY' series (linked).
                                          I couldn't find anything about Samwha...
                                          09-06-2023, 08:30 PM
