DC voltage drops after replacing the capacitor!
  • hamid.reza
    • Aug 2014
    • 6
    • Iran
    Someone asked me to take a look at his 6 years old, heavily used satellite receiver. To my amazement, despite the satellite receiver, being from a brand with a notorious reputation of being of inferior quality, it was working pretty good.
    I checked the voltages:
    3.33 ===> 3.36
    3.33 ===> 3.36
    8.00 ===> 7.64
    12.0 ===> 11.7
    23.0 ===> 22.7
    I changed the only 1000uf 10v SamYoung SHL series with 1000uf 35v SamYoung NXB series. I did this because most of the time in this type of satellite receivers 1000uf caps fails!
    Problem: I checked the voltages again:
    3.33 ===> 3.36
    3.33 ===> 3.36
    8.00 ===> 7.44
    12.0 ===> 11.5
    23.0 ===> 22.5
    I don't know what happened!! Could someone please shed some lights?
    For your reference:
    SamYoung NXB is a Very low impedance cap. Impedance is 0.02. I checked it with ESR meter and it was 0.021. the capacitance also was very close to 1000uf.
    SamYoung SHL is not something special. The capacitance has deteriorated to about 800uf and ESR is about 0.4!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: DC voltage drops after replacing the capacitor!
    It should be fine, the voltages might of dropped due to the capacitors being new and filtering out more ripple, or the esr of the new caps.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      it because you replaced high impedance caps with low impedance caps. no issues here.
      Follow the white rabbit.
      • hamid.reza
        • Aug 2014
        • 6
        • Iran
        Doesn't it have to be as close as possible to the output voltage labeled on the board?
        Isn't it possible that some components are running undervolt? Doesn't this cause instability?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Let me rephrase that, you changed the impedance of some of the caps that will affect the voltage, and as long as the voltages are with in 1 volt of there rated spec it should be fine.
