...that actually say Panasonic on them. Anyone know why? I have never seen them but with the Matsushita M in the square. Photo is from JonnyGuru's In Win Commander III 800W PSU review.
Panasonic capacitors
Re: Panasonic capacitors
Yeah. Everything else about them looks genuine. The vent stamp and colours look correct for that size.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
The D/C is 32nd week of 2014. A new style? Generally or just large can types?PeteS in CA
****************************Comment
If that date code is correct then they're surely fake since OklahomaWolf wrote the review on 6/10/13
http://www.jonnyguru.com/modules.php...Story&reid=343Comment
You may know that Matsushita has changed its name to Panasonic Corporation, to make their corporation name more "global", since many people recognize the Panasonic brand.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
I wonder if that is the actual date code because from this thread, someone from Panasonic responded saying the date code is basically month and day without the actual year.
http://www.element14.com/community/t...ailure-concernComment
Good catch, as they said 0921 means either means either September 21 of 2000 or 2010 so the first digit would be the same as the last digit of the year, they should stick to 2 digit years to make it easier. So in the case of the pictures above, if it was 2013, December 14, would it be 31214 then?Comment
Looks like it could be because they are larger. (And hence have more room to put something like that)
I think I've seen Nippon Chemi-Con capacitors that actually say that in the shield logo on larger capacitors. They just have more room, so why not put their name on it? xDMuh-soggy-kneeComment
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
...1 Photo11-20-2024, 08:52 PM -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
- Loading...
