Capacitor problem?
  • dvcochran
    • Aug 2014
    • 3
    Capacitor problem?
    Not sure if this is the right site but any help is appreciated.
    I have a small 2 horsepower 120VAC portable air compressor that starts fine on the line voltage in my shop. I have used it many times on a generator (5000 watt)but now it will not start when the pressure switch calls for it to run. The motor turns slowly until it trips out. If I discharge the air then compressor will start but even then it seems to struggle more than when it is connected to house current. I have tried it on two different generators with the same results. Any ideas?
    I have not tested the capacitor because it is starting fine on house current but here is the capacitor info:
    XUFENG
    CBB60 150uF +/- 5%
    250VAC C SH P0
    25/70/21 50/60HZ
    09.2008
    Thanks for your help,
    David Cochran
  • selldoor
    Slow Learner
    • 7870
    Re: Capicitor problem?
    Aloing with many other things I know nothing about generators or compressors but I guessed the question may have been asked before so:
    https://uk.answers.yahoo.com/questio...7233931AAQkVba
    may go some way to helping.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Are you sure it's 150uF and not, perhaps, 15uF. The 250VAC rating and the 5% tolerance suggest to me that it's a motor-run film capacitor, and 15uF seems to me a more reasonable value (maybe it's 15.0uF?). Motor run capacitors help heavily loaded motors start up, which is the problem you're trying to fix.
      PeteS in CA
      • PeteS in CA
        • Aug 2005
        • 3581
        BTW, I suggest removing the telephone # from your post, as BadCaps is visible publicly.
        PeteS in CA
        • c_hegge
          • Sep 2009
          • 5219
          Re: Capacitor problem?
          Agreed. Phone numbers should never be made public like that. I fixed the spelling in the title too.
          • pc7fan
            • Aug 2013
            • 52
            I agree too... phone numbers shouldn't be published in a public forum :p
            • dvcochran
              • Aug 2014
              • 3
              Thank you for the warning about the phone number. It is removed. Can anyone help me with my problem? It may be a 15.0 uF capacitor and I just cannot see the period. I just know it starts fine on house current but not from two different generators. Any ideas?
              Thanks,
                • 31017
                got a foto of the cap?
                  12/24 volt compressor cooler box inverter capacitor failure
                  by sam_sam_sam
                  This is my son’s cooler for his semi truck for his drinks the other day it started short cycling ( running for a second or two then shutting down ) and restarting four or five times then going into an error power cycle the controller then it would do the same thing again
                  Found a 47uf@63 volts double the ESR value of a new one
                  The 220uf@16 volts same as a new but 220uf@35 volt replacement capacitor
                  The main filtering capacitor was not replaced because I did not have that was not too tall
                  Where the 220uf capacitor is some type of switching power...
                  08-30-2022, 05:28 PM
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
