How to Identify My GPU When CPU-Z and Physical Labels Disagree?
This topic has been answered.
  • Andriy Andrusyk
    • May 2025
    • 12
    • Ukraine
    I recently bought a used GPU that was advertised as an MSI GeForce GTX 1080 Ti. The backplate label also identifies it as a GTX 1080 Ti, and the label looks untampered.
    However, when I run CPU-Z, it detects the GPU as a Radeon RX 480.
    I inspected the PCB and found a second label near the gold connector reading: V341 VER:1.1 From what I've found online, V341 PCBs are typically used for Radeon RX 480, while GTX 1080 Ti cards usually use a V360 PCB.
    Is it possible the card was BIOS-modded or relabeled? What's the most reliable way to verify the actual GPU model I have?
    Click image for larger version  Name:	MSI2.jpg Views:	0 Size:	167.4 KB ID:	3636499
  • Answer selected by Andriy Andrusyk at 05-14-2025, 08:29 AM.
    m1ch43lzm
    • Mar 2019
    • 1025
    • Peru
    Also the power connector, the GTX 1080Ti uses 1 8-pin connector and 1 6-pin power connector, or 2 8-pin power connectors from the power supply (depending on manufacturer), while the RX 480 uses either a 6-pin or 8-pin power connector (depending on manufacturer)
    If you mod the vBIOS on an AMD card you also need to install patched AMD drivers, as the drivers wouldn't load on a modded vBIOS (back in the day when the RX470/480/570/580 were used for crypto mining some people used modded vBIOS with tighter RAM timings to get better hashrate)
    You can post a screenshot of GPU-Z to check
    I only see 1 power supply connector on your card
    The "warranty sticker" at one of the screws, those stickers are sold at aliexpress, i doubt a GPU released 8 years ago hasn't been opened to change thermal paste
    Picture of the MSI GTX 1080Ti Gaming X, spot the differences at the power connectors, also it has 2 SLI connectors near the rear bracket, also notice the GEFORCE GTX branding
    Google "msi gtx 1080ti gaming x review" to get more pictures of the card
    Click image for larger version  Name:	06-msi-geforce-gtx1080ti-gaming-x-11g.jpg Views:	0 Size:	76.7 KB ID:	3636640
    Looks like the seller made a new label, if you bought locally i'd get a refund as "not as described"
    • spleenharvester
      • Mar 2010
      • 921
      It's an RX 480. If you want to be sure you can take the HSF off and look at the core markings. And also the driver it's running. (Plus it's easy to relabel two near-identical looking GPUs... but you can't exactly mod a BIOS from AMD to Nvidia).
      I am guessing you bought this from AliExpress or similar? The RX 480 is significantly less powerful than the GTX 1080 Ti so more than likely you have been hit with a relabelling scam.
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • m1ch43lzm
        • Mar 2019
        • 1025
        • Peru
        • Andriy Andrusyk
          • May 2025
          • 12
          • Ukraine
          You're right — it turns out to be a case of fraud. I was sold an MSI Radeon RX 480 instead of the advertised MSI GeForce GTX 1080 Ti. After comparing with pictures of genuine cards, the evidence is clear. The seller has disappeared into thin air. Thank you!Click image for larger version  Name:	MSI3.jpg Views:	0 Size:	83.0 KB ID:	3636738
          • thesame
            DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
            by thesame
            Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
            The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
            02-27-2024, 04:31 AM
          • silver60618
            Lenovo Legion 7 - Help Identify IC
            by silver60618
            Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
            I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
            Any help would be appreciated...
            07-02-2025, 12:16 PM
          • chth96
            How can I identify varistor which have been blew up?
            by chth96
            I mistakely pluged 100v japanese retro game console to 220v outlet.
            So It seems that glass fuse and varistor have been blew up.
            I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
            Is there any way to identify varistor type in my sega saturn PSU?
            Any reply would be appreciated.
            EDIT:
            It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
            11-26-2023, 08:52 AM
          • freakorio
            Need Help To Identify Component on Ymain LJ41-05120A
            by freakorio
            Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
            05-21-2024, 02:32 AM
          • baiceanu_stefan
            nm-f251 Schematic, boardview or help identify componente
            by baiceanu_stefan
            Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
            04-24-2024, 12:49 AM
