Epoxy Buger Caps
  • JASTECH
    • Jul 2014
    • 27
    • U.S.A.
    Epoxy Buger Caps
    Howdy, I'm needing to replace these EBC's but can't seem to locate them or better yet an upgrade. The only thing I see on these little burgers is "n 5 c" then under a bit more it reads "MAX 250". I let my meter dance with the Cap and this is what came out.
    99.8nF
    Mag/Phase 1.588 KΩ
    Impedance 11.82-16.83
    j1.587 KΩ
    Admittance 4.4-5.6u
    j628.2uS
    Thanks, JASTECH
    Re: Epoxy Buger Caps
    Can we see the pictures? and what are you measuring it with?
    • JASTECH
      • Jul 2014
      • 27
      • U.S.A.
      budm, Yes I'll post some pics in a few minutes.
      My meters I use? Well ok, Fluke 45, Simpson 160, Simpson 260, Keighley 2000, Fluke 8600A, Atlas LCR45.
        I am sure you are not using the Simpson, Fluke to get all those readings.
        • JASTECH
          • Jul 2014
          • 27
          • U.S.A.
          Here is a pic.
          • JASTECH
            • Jul 2014
            • 27
            • U.S.A.
            budm, they can only achieve part of what "can" be gathered. Any ideas on where to get the Caps I'm needing sir?
              The small yellowish/brown caps (I can see 6 of them in the picture)? Did you test them off the board or in circuit? They are Ceramic bypass caps (typical value is 0.1uF (you show the reading of 99.8nF which is within the spec of 100nF (0.1uF) and need to be tested off the board. I would suspect the electrolytic caps to be dried out by now, the ceramic cap when they failed, they failed as shorted circuit or have leakage resistance. Testing cap in circuit cannot be reliable due to other components are also connected to the cap.
              What kind of equipment is this?
              X7R, Z5U Ceramic cap.
              https://cdn.badcaps-static.com/pdfs/...c68cd3fc73.pdf
              http://www.digikey.com/product-detai...91-1-ND/818348
              http://www.digikey.com/product-detai...54-1-ND/818311
                • 31301
                yellow are axial multilayer ceramic.
                probably .1uf 50v
                i buy those in large numbers to replace old broken disc and mylar caps.
                • JASTECH
                  • Jul 2014
                  • 27
                  • U.S.A.
                  stj, is a upgrade available? Their are a couple smaller mac's that I haven't tested and can't read the print on them unless removed. Might get a digital mono scope for USB.
                    • 31301
                    mac?
                    upgrade?
                    what exactly is the problem your having?
                      Yeah, good question,, upgrade to what and what do you expect it to do with the upgrade?
                      The board you show in the pictures looks like some kind of motor control, we do not knw exactly what you are trying to do yet.
                      • JASTECH
                        • Jul 2014
                        • 27
                        • U.S.A.
                        Very good y'all, its a control board for HVAC,. It don't seem to take the heat of the heater coils too well I think. Its mounted close to coils. The components need to handle humidity too. So I wanted to upgrade board.
                          If you want to help to protect it from humidity, you will need to use conformal coating which it does look like it has some on the board already. You may need better heat shield or mount the PCB further away from the heat source. May be the board has circuit function problems.
                          Learn more here: http://www.humiseal.com/conformal-coating/
                            • 31301
                            beaten to the post button.
                            • JASTECH
                              • Jul 2014
                              • 27
                              • U.S.A.
                              budm, Thanks for link, I'll read it now. Was thinking the "conformal coating" won't allow heat to dissipate from passive semiconductors?
                              • JASTECH
                                • Jul 2014
                                • 27
                                • U.S.A.
                                Budm, Read link, thanks. It is difficult to remove the coating where needed on this board. I try to do my soldering at 350°, desoldering with the coating will take a bit more. Also, I'll be replacing the solder with SnAgCu .32 Alpha Telecore Plus, it will be safer for all concerned.
                                • JASTECH
                                  • Jul 2014
                                  • 27
                                  • U.S.A.
                                  Word correction messed up one of the meter names above, thought I would correct it for those who may not know, its "Keithley 2000".
                                  • JASTECH
                                    • Jul 2014
                                    • 27
                                    • U.S.A.
                                    stj, Thank you too, button beaten or not, lol.
                                    • JASTECH
                                      • Jul 2014
                                      • 27
                                      • U.S.A.
                                      stj, mac= multilayer-axiel-cap, guess my terms are just too old or bassackwards for nowadays sometimes, sorry, I can and will learn more.
                                      Are there other types of caps that are of higher quality, like barrel type?
                                        • 31301
                                        no
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
