Blown Capacitor Identification
  • james_olver
    • Jun 2014
    • 5
    • United Kingdom
    Its a long shot but a capacitor blew on my hand mixer:
    http://www.amazon.co.uk/Rachel-Allen...pr_product_top
    I cannot make out the markings but wondered if anyone could help with the identification:
    Thank you
  • mariushm
    • May 2011
    • 3799
    Re: Blown Capacitor Identification
    What you have there is something wrapped in heatshrink (a tube made of thermo-plastic material that shrinks when there's heat applied). You'll have to get a sharp blade or something similar and carefully cut away that tube of heatshrink and then you should see the markings of the capacitor.
    It looks to me like that's actually a FUSE... the fuse is in that tube of heatshrink so that if the fuse pops, you don't get shards of glass or ceramic material everywhere.
    On the metal caps of the fuse, there should be a number (the current at which point the fuse breaks) and a digit (T for example for "time delay")
    • james_olver
      • Jun 2014
      • 5
      • United Kingdom
      Hi mariushm, thank you for the quick reply.
      You were quite right it was a fuse wrapped in heat shrink!
      The markings are T3 15A 250V which looks like quite a common fuse which I can now replace and repair the mixer.
      Thank you for your help.
      • selldoor
        Slow Learner
        • 7870
        You may want to consider why the fuse blew?
        Any signs of other damage?
        If you replace with a glass fuse replace the shrink wrap.
        • paulnetv
          • Mar 2014
          • 22
          • United Kingdom
          Erm, I don't want to throw a spanner in the works here but I would be looking very carefully at that fuse again.
          Are you sure it is not a T3.15A 250V fuse???? Replacing a 3.15A with a 15A would clearly be a bad thing to do!
          It would be some seriously meaty hand mixer that used a 15A fuse!
          • mariushm
            • May 2011
            • 3799
            Yes, it's probably a 3.15A fuse.. after all, the product has a 600w motor, so at 240v mains, you have 600/240 = 2.5A. The T is for time delay, which is needed for the brief moment when the motor starts up and puls quite a bit more than 3A.
            Here's something that would work for you and you can probably buy it from them:
            pack of 10 , 1.64 pounds : http://cpc.farnell.com/_/cf2470ff-3-...20This%20Range
            It looks different, but it's time delay , 3.15a , 250v ... just isolated in epoxy instead of glass.
            If you want the classical look, you have those as well (but these don't come with leads, you'll have to solder leads on them and put some heatshrink on them or be inovative (example, get a plastic pen and break the tube and put the fuse inside and use some tape over the plastic) :
            http://cpc.farnell.com/littelfuse/02...15a/dp/FF02791
            http://cpc.farnell.com/littelfuse/02...20This%20Range
            http://cpc.farnell.com/schurter/0034...20This%20Range
            http://cpc.farnell.com/cooper-bussma...15a/dp/FF01263
            http://cpc.farnell.com/multicomp/mcf...15a/dp/FF01376
              • 31019
              i think the guy is gone and wont be back.
              atleast until he wants help again!
              • paulnetv
                • Mar 2014
                • 22
                • United Kingdom
                I hope he hasn't gone out and bought his 15A fuse already then
                  • 31019
                  look on the bright side - it wont blow again!
                  • Babbar
                    by Babbar
                    04-12-2024, 01:12 AM
                  • dellxps15
                    macbook a1707 15 inch trackpad dead. blown fuse identification
                    by dellxps15
                    hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                    another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                    04-30-2024, 10:48 AM
                  • drscoot
                    HP X360 convertible battery blown fuse error, not charging
                    by drscoot
                    HP Modelnumber: 14-dh0061nb​
                    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                    All these 3 batteries are charging...
                    12-15-2023, 05:54 AM
                  • beetle1303
                    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                    by beetle1303
                    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                    01-13-2025, 08:49 PM
                  • MeetingIncapable
                    Blown capacitor repair on MSI Radeon RX 5700 XT MECH OC
                    by MeetingIncapable
                    I am new to repairing computer electronics, so excuse any mistakes I make.
                    A friend of mine had a broken graphics card (MSI Radeon RX 5700 XT MECH OC) and gave it to me. It does not power on or show any signs of life.
                    I identified what looks like the remains of a blown capacitor at the bottom of the board (see picture).
                    I wanted to replace the capacitor, but I have two questions:
                    • Does this repair have a chance of working? or is a blown capacitor a sign something else is wrong?
                    • How do I determine the rating/value of this capacitor? or something
                    05-04-2024, 09:56 AM
