GeForce 6800GT recap, need help identifying caps and finding replacements
  • fl0w
    • Oct 2024
    • 6
    • France
    I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
    But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
    I need to replace:
    • 2x 2.5V 1500µF => I plan to use this
    • 2x 16V 330µF=> I plan to use this
    • 1x 6.3V 680µF=> I plan to use this
    Am I correct with the cap choices?
    Thanks for your help.
    • 31072
    polymers are a good choice - make sure the diameters are the same or the lead pitch wont match
    • fl0w
      • Oct 2024
      • 6
      • France
      Hi, thanks for your reply. Diameters are identical, I'm just worried about differences in ESR values, and I'm unable to find the ESR values on the caps. I only found that the KZG are low ESR, without any additional information.
        • 31072
        on gpu's low esr is essential because of the frequencies they run the psu section at.
        • fl0w
          • Oct 2024
          • 6
          • France
          So the caps I mentioned should be correct?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            They look fine but there is probably no point in replacing those Fujitsu caps: they are good quality...
            And when replacing the UCC KZG caps I would go for a same-same replacement (same capacitance).
            Something like this: https://eu.mouser.com/ProductDetail/...PWDmuM8Q%3D%3D
            • fl0w
              • Oct 2024
              • 6
              • France
              Alright, I will order this reference then. Thank you Per Hansson. The Fujitsu are not swelling so I won't replace these ones.
