bi-polar electrolytic vs polyester?
    • 30944
    i have a bit of test gear with a 4" crt.
    it uses a bipolar cap to couple the scancoil to ground.
    any experts in old analog stuff think it is safe to use a polyester box instead?
    will it work?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4925
    • New Zealand
    Re: bi-polar electrolytic vs polyester?
    I'm no expert but if it has a high enough voltage rating I suppose it would work and not blow up or anything.
    But, they may be counting on some property of an electrolytic for proper operation, so it might work but your picture might be wrong.
    -David VanHorn
    • japlytic
      • Oct 2005
      • 2086
      I had no problem with replacing bi-polar horizontal deflection yoke coupling electrolytic capacitors with polyester ones.
      But size may be an issue.
        • 30944
        size is no issue,
        that's exactly what i wanted to hear.
        a couple of questions.
        did you match the uf,
        and did the difference in esr cause the width of the image to shrink/enlarge?
        because i'v got no width coil on this monitor - so it may be better if i match the esr rather than the uf.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4925
          • New Zealand
          Why not just get another bipolar electrolytic? They are very easy and cheap to buy.
          -David VanHorn
            • 30944
            in new zealand maybe.
            my suppliers that dont have a huge minimum order dont stock them.
            • Helping Friendly
              • May 2014
              • 5
              Makes a decent point
                • 30944
                i dont want $50 worth of them,
                nor do i want to wait till i need to spend that much on other stuff.
                • Adenitz
                  Replace electrolytic cap with bipolar one
                  by Adenitz
                  can I use this cap:
                  https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                  Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                  to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                  What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                  Thanks.
                  02-02-2022, 07:44 AM
                • render1967
                  Problem with the Logitech G27 gaming steering wheel gear lever
                  by render1967
                  Hello! First, please excuse me if my English is not good enough because it is not my native language!
                  Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
                  11-13-2021, 01:35 PM
                • tony359
                  Bipolar capacitor for vintage Apple CRT monitor
                  by tony359
                  Good day all,
                  I have a question about some old monochrome Apple monitors.
                  Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
                  A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
                  The new capacitor:...
                  08-12-2024, 03:27 AM
                • AstutePauciloquent
                  Requesting Help Identifying tiny Aluminium electrolytic
                  by AstutePauciloquent
                  Hi wonderful people. I have a MS-6315 P3 motherboard with very tiny Aluminium electrolytic capacitors. I've made an attempt to identify them from what ive learned so far they might be
                  Aluminium Electrolytic
                  G = Series
                  10 uF
                  16 = Volt
                  104 Date code 2001 April? (not really important, but interesting)
                  Please help to confirm or correct if i am wrong. Thank you
                  10-20-2023, 06:29 AM
                • ten-d
                  Nippon Chemi-con 100uf 100v BP electrolytic cap
                  by ten-d
                  Hi all!
                  I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                  01-30-2024, 05:18 PM
