bi-polar electrolytic vs polyester?
    • 31291
    i have a bit of test gear with a 4" crt.
    it uses a bipolar cap to couple the scancoil to ground.
    any experts in old analog stuff think it is safe to use a polyester box instead?
    will it work?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: bi-polar electrolytic vs polyester?
    I'm no expert but if it has a high enough voltage rating I suppose it would work and not blow up or anything.
    But, they may be counting on some property of an electrolytic for proper operation, so it might work but your picture might be wrong.
    -David VanHorn
    • japlytic
      • Oct 2005
      • 2086
      I had no problem with replacing bi-polar horizontal deflection yoke coupling electrolytic capacitors with polyester ones.
      But size may be an issue.
        • 31291
        size is no issue,
        that's exactly what i wanted to hear.
        a couple of questions.
        did you match the uf,
        and did the difference in esr cause the width of the image to shrink/enlarge?
        because i'v got no width coil on this monitor - so it may be better if i match the esr rather than the uf.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5095
          • New Zealand
          Why not just get another bipolar electrolytic? They are very easy and cheap to buy.
          -David VanHorn
            • 31291
            in new zealand maybe.
            my suppliers that dont have a huge minimum order dont stock them.
            • Helping Friendly
              • May 2014
              • 5
              Makes a decent point
                • 31291
                i dont want $50 worth of them,
                nor do i want to wait till i need to spend that much on other stuff.
                • Adenitz
                  Replace electrolytic cap with bipolar one
                  by Adenitz
                  can I use this cap:
                  https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                  Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                  to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                  What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                  Thanks.
                  02-02-2022, 07:44 AM
                • render1967
                  Problem with the Logitech G27 gaming steering wheel gear lever
                  by render1967
                  Hello! First, please excuse me if my English is not good enough because it is not my native language!
                  Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
                  11-13-2021, 01:35 PM
                • tony359
                  Bipolar capacitor for vintage Apple CRT monitor
                  by tony359
                  Good day all,
                  I have a question about some old monochrome Apple monitors.
                  Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
                  A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
                  The new capacitor:...
                  08-12-2024, 03:27 AM
                • madscientist750
                  Replacing electrolytic caps by solid caps on old motherboards
                  by madscientist750
                  I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                  I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                  I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                  10-19-2025, 06:10 AM
                • Perry Babin
                  Electrolytic cap endurance
                  by Perry Babin
                  From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                  Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                  Why do polymer capacitors...
                  10-18-2025, 05:21 PM
