bi-polar electrolytic vs polyester?
    • 31213
    i have a bit of test gear with a 4" crt.
    it uses a bipolar cap to couple the scancoil to ground.
    any experts in old analog stuff think it is safe to use a polyester box instead?
    will it work?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5038
    • New Zealand
    Re: bi-polar electrolytic vs polyester?
    I'm no expert but if it has a high enough voltage rating I suppose it would work and not blow up or anything.
    But, they may be counting on some property of an electrolytic for proper operation, so it might work but your picture might be wrong.
    -David VanHorn
    • japlytic
      • Oct 2005
      • 2086
      I had no problem with replacing bi-polar horizontal deflection yoke coupling electrolytic capacitors with polyester ones.
      But size may be an issue.
        • 31213
        size is no issue,
        that's exactly what i wanted to hear.
        a couple of questions.
        did you match the uf,
        and did the difference in esr cause the width of the image to shrink/enlarge?
        because i'v got no width coil on this monitor - so it may be better if i match the esr rather than the uf.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5038
          • New Zealand
          Why not just get another bipolar electrolytic? They are very easy and cheap to buy.
          -David VanHorn
            • 31213
            in new zealand maybe.
            my suppliers that dont have a huge minimum order dont stock them.
            • Helping Friendly
              • May 2014
              • 5
              Makes a decent point
                • 31213
                i dont want $50 worth of them,
                nor do i want to wait till i need to spend that much on other stuff.
