How many caps should i replace.
  • gastorgrab
    • May 2007
    • 320
    (This is post #2 for me)
    I've already had success recapping a EPoX 8RGA board but i didn't replace everything above 470uF. Should i have?
    I decided that if any cap showed signs of swelling i would replace all of that type. One type i left, showed absolutely no signs of swelling or leaking.
    The board seems to work without any drawbacks.
    Should i expect problems later?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: How many caps should i replace.
    they look like sanyos should be fine
    what caps did you use
    • gastorgrab
      • May 2007
      • 320
      When i ordered the caps the only ones i could find from the 'Known Good Caps' list were these (from DigiKey)
      ELXZ6R3ELL152MJ20S - 1500uF, 6.3v, 10mm diameter LXZ Radial
      ELXZ6R3ELL102MH15D - 1000uF, 6.3v, 8mm diameter LXZ Radial
      I have since discovered Mouser and Farnell, and i'm a little more proficient in searching for parts. DigiKey has many more compatible parts available.
      I also noticed two other places in the states that cater to MB repair.
      STSI has a supply of Panasonic FC caps
      http://www.stsi.net/storefrontprofil...104074&c=91679
      and Computek has something they identify as only:
      "high quality Japanese ultra low ESR & low impedance computer grade caps found in many high end motherboards, power supplies, and LCD monitors."
      http://www.computekinc.us/prod01.htm
      A part number would be nice.
      • dungbeetle
        • May 2007
        • 94
        I just bought some from Computek and they are Rubycon MCZ and MBZ's. Look like the real thing too
        Regards,
        db
        • gastorgrab
          • May 2007
          • 320
          Were they prompt? (PayPal and i are trying to make peace, so i need a source that accepts credit card.)
          Yes, i think they are.
          I did leave a row of GSC caps on the board behind the Sanyos. They didn't show any signs of swelling............but they're 'GSC' caps. (I opened the case back up to double-check.)
          Can i assume that not all of the caps on a MB work to their limit?
          (When it's time to take out the trash should i make sure to take out ALL the trash?)
          • Rainbow
            • Aug 2005
            • 1372
            That GSCs will die - sooner or later. As it's probably worst cap brand ever, I always replace them all (unlike OST, TEAPO or G-Luxon).
            • gastorgrab
              • May 2007
              • 320
              Won't they all die sooner or later?
              In a couple of years time this board will be so slow it may be completely unusable anyway.
              • gonzo0815
                • Feb 2006
                • 1600
                No, GSC is the one of the worst brands, they do failfore shure and probably soon.
                A good cap will outlast the usefull live of a PC system with ease. But those definitely not.
                • dungbeetle
                  • May 2007
                  • 94
                  Yes! I ordered them on a Thursday afternoon and had them Saturday. I was impressed.
                  Regards,
                  db
                  • gastorgrab
                    • May 2007
                    • 320
                    Hmmmmmm.....
                    ......all the garbage above 470uF as show here?;
                    http://en.wikipedia.org/wiki/Capacit...ing_capacitors
                    Typically, only electrolytic capacitors with rated at 470 uF and above will fail. The smaller capacitances are presumably implemented with different electrolytes. They are also typically used for coupling and not voltage control. As such, they are not heavily stressed.
                    Usually, when motherboards are recapped, all the 'bad brand' capacitors of 1000 uF and above and any 470 uF or above in the vicinity of the VRMs (Voltage Regulators), CPU, chipset, memory, or AGP slot are replaced. Capacitors in other areas are typically used for signal coupling and not voltage control. ESR is not critical for coupling capacitors so one that is simply operating out of range normally does not cause problems. (Although a completely failed coupling capacitor will.)
                    Failing capacitors with smaller values are not unheard of, nor are bad brand capacitors (of any value) failing electrically with no visible symptoms, so replacing all capacitors may be advisable, particularly if the existing capacitors are from a questionable manufacturer.
                    ....or all the garbage, period?
                    I'm there right now, and yes they do accept credit card. It looks like even the credit card orders are routed through PayPal. It doesn't surprise me since i found the site by a posting on ebay.
                    • tazwegion
                      • Jun 2006
                      • 444
                      Generally, it's considered 'best practice' to replace all the trash capacitors 1000uF and up on any given platform you're repairing/recapping
                      BTW is that a Teapo I see hiding up the back of the RAM slots (in the first picture)?
                      Viva LA Retro!
                      • gastorgrab
                        • May 2007
                        • 320
                        • gastorgrab
                          • May 2007
                          • 320
                          That's funny.
                          That Teapo is the same value as the 10mm GSC caps i already replaced. - (1500uF, 6.3v, 10mm)
                          Why would they use a different manufacturer for this one part?
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            May be the GSC stock was sold out, and thus they order a few milions of teapos.
                            • gastorgrab
                              • May 2007
                              • 320
                              Well i didn't realize that the one Teapo was part of that same group. Had i seen this post i would have changed it the first time.
                              • gastorgrab
                                • May 2007
                                • 320
                                Yeah, i got the same here. These will go into the BX133;
                                10v, 1000uF, Rubycon MCZ to replace the 10v, 1000uF JackCon
                                10v, 1500uF, Rubycon MBZ to replace the 6.3v, 1500uF JackCon
                                I couldn't seem to find an 8mm, 6.3v, 1500uF cap anywhere that accepts credit card......ummmm.....without having to buy a quantity of 400 pieces.
                                • gastorgrab
                                  • May 2007
                                  • 320
                                  Second order from Computek, not so good.
                                  The 2200uF, 16v, 10mm caps are Rubycon, but they are PX series. These aren't low ESR caps are they?
                                  Yes sir, a part number would really be helpful
                                  Of the second cap in the same order, what came are 470uF, 16v, 8mm Rubycon MBZ.
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    i think you should complain and get the PX replaced. they are not what i would call "motherboard capacitors"
                                    • gastorgrab
                                      • May 2007
                                      • 320
                                      Is there a spec sheet for the PX series somewhere on this forum?
                                      I like to be prepared when i start trouble.
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • edith
                                          Caps and how to find one to replace
                                          by edith
                                          Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
                                          Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
                                          Thank you!
                                          06-11-2023, 05:00 PM
                                        • Mattz_GT
                                          Which caps to replace: ECS P4M800Pro-M V1.0A
                                          by Mattz_GT
                                          It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
                                          I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
                                          Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
                                          Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
                                          PS. Additional diagnostic,...
                                          01-22-2025, 12:12 PM
                                        • rewease
                                          Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                                          by rewease
                                          There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                                          Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                                          Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                                          09-17-2023, 12:53 AM
