Bi Polar vs. Non Polarized Caps
  • landyboy
    • Apr 2013
    • 443
    Any difference? Are they interchangeable?
  • mariushm
    • May 2011
    • 3799
    Re: Bi Polar vs. Non Polarized Caps
    What a stupid question.
    A polarized capacitor has negative and positive and it matters how you put it in the circuit. If you put it the other way around, it will get damaged.
    A bipolar capacitor doesn't care about the polarity, because it's built in a special way: "full-thickness oxide layers are formed on both the aluminum foil strips prior to assembly. On the alternate halves of the AC cycles, one of the foil strips acts as a blocking diode, preventing reverse current from damaging the electrolyte of the other one." (shameless wikipedia copy paste because apparently people can't fucking google : http://en.wikipedia.org/wiki/Electrolytic_capacitor )
    They're also called not polarized or non polar (NP) capacitors so in a way they're the same thing. But don't confuse them with other types of capacitors which are by their nature without polarity (ceramic capacitors, film capacitors etc)
    You can make electrolytic capacitors that don't care about polarity by connecting two in series with the same polarity ex -.. + +.. -
    See https://cdn.badcaps-static.com/pdfs/...bd1d3d06f2.pdf page 13. And the whole pdf in general as educational material.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Follow the white rabbit.
      • landyboy
        • Apr 2013
        • 443
        @mariushm. Sorry for the "stupid question" What is even more stupid is that you took the time out of you obvious busy life to even reply.
        "A polarized capacitor has negative and positive and it matters how you put it in the circuit. If you put it the other way around, it will get damaged."
        My question had nothing to do with Polarized capacitors.
        Sorry we can't all be experts!
        • LLLlllou
          • May 2011
          • 201
          Funny, that sure looks like a question . . . . about polarized capacitors.
          • landyboy
            • Apr 2013
            • 443
            No not really, As we already established I am no expert but a Polarized Cap has a definite polarity and believe it or not I already knew that. I did "google" my question first before I posted this thread. From what I read about NP and BP Caps they appeared to be interchangeable since neither had a specific polarity. I just thought since I do respect a lot of members on this site I would ask the question here. Maybe one of the Moderators can chime in here, possibly they should add a disclaimer that only intelligent questions are permitted and you two can be the judges.
            • brethin
              • Dec 2008
              • 1907
              Not sure why people can't read but the question was Bi Polar vs. Non Polarized Caps, Any difference? Are they interchangeable?
              The correct answer is:
              No there is no difference, NON Polarized Caps and Bi Polar Caps are the same just different names, and yes they are interchangeable.
              Polarized Caps (Which he did not ask about) must follow polarity to work correctly and prevent damage.
              • landyboy
                • Apr 2013
                • 443
                Thank You!
                • mockingbird
                  • Dec 2008
                  • 5484
                  It's actually not a stupid question at all...
                  I think I read on this forum somewhere that non-polarized caps always become polarized when used in a circuit.
                  ...or am I mistaken in my assumption that BP caps aren't necessarily used in circuits without polarity per se (or circuits that fluctuate between + and _... does this exist?), but rather in applications where they can be inserted either way and the circuit is not susceptible to error in manufacture... If this is the case, then shouldn't a BP cap be replaceable with a polarized cap after the polarity of the circuit has been determined?
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    This
                    There is no need to be rude mariushm
                    • mariushm
                      • May 2011
                      • 3799
                      I think you know me guys, and you know that I'm not normally rude, and I do my best to help people here.
                      In this case, the OP asked in another thread and got his reply, then he decided to create a new thread anyway instead of continuing there.
                      Here's the previous thread: https://www.badcaps.net/forum/showthread.php?t=31214
                      In addition, a simple google search or browsing through Technical Notes of various capacitors manufacturers would have clarified this issue.
                      Rubycon , Nippon Chemi Con, Nichicon, they all have technical notes and education material almost on the main page of their websites, explaining how capacitors are manufactured and explain everything.
                      • theokretes
                        • Jul 2013
                        • 49
                        I have some analog synthesizers that utilize bi-polar electrolytics in specific areas (assuming that the electrons must flow either way). I haven't been able to source replacements, and the only ones I could find were hideously expensive and marketed in audio applications (which I guess would make sense given that they are analog audio circuits). I'll have to browse digikey later.
                        Not many people even know that bipolar electrolytics exist if you ask them. Sort of like if you ask musicians about temperaments or 440Hz being introduced recently as a master pitch.
                        • CapSwapper
                          • Feb 2014
                          • 69
                          Digikey has them, the Nichicon ES series. the prices aren't too bad
                          http://www.digikey.com/product-searc...=0&pageSize=25
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4954
                            • New Zealand
                            Yeah but that thread got a bit derailed by someone else with confusion over NP and BP capacitors, so I can understand why he would want to post another thread for clarification.
                            -David VanHorn
                            • senz_90
                              • Aug 2013
                              • 328
                              • Indonesia
                              LOL. that's my fault . I realized my fault and feel that I have ever read on my country language site mention 2 type caps on electronic e.g Non polar and Bipolar caps is different. Maybe there is some typo on them.
                              "There is no shortcut to be successful. No pain, no gain."
                              Best Regards
                              Rudi
                              Thank You
