Help, order mistake?
  • ron350
    • Feb 2014
    • 296
    I just made an order from badcap.net and made a mistake.
    Can the mistake be corrected or will I have to make another order?
    Ron
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Help, order mistake?
    Hi you should email sales@badcaps.net regarding this.
    • ron350
      • Feb 2014
      • 296
      Thanks I sent a email.
      One of those days when every thing goes wrong.
      Ron
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Ron
        Haha I feel ya.
        • GraphicMan
          Pioneer amplifier A-205 Relay not clicking after a mistake i made
          by GraphicMan
          Hello guys
          Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
          sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
          i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
          on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
          05-05-2024, 06:20 AM
        • AgustinLorenzo
          [BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
          by AgustinLorenzo
          Hi boys,
          This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
          Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
          Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
          After having carried out all the frequent...
          10-15-2023, 07:31 AM
        • ruletero
          La-k035p photo of moved components please
          by ruletero
          Hi everyone
          Somebody has a photo of the correct order of this resistances?
          I made a mistake and moved 2 resistances, I put them like I guess they goes but I'm not sure and not boardview or schematic is available
          Mobo: LA-K035P
          Very thank you....
          11-13-2024, 10:29 AM
        • elmontador
          LG RL4 (i made a mess)
          by elmontador
          Hello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful...
          09-02-2025, 03:31 AM
        • alex26
          Lenovo ideapad gaming 3 laptop. I did a big mistake
          by alex26
          Hello. I have a Lenovo ideapad gaming 3 laptop. I did a big mistake, more precisely I powered a laptop with 61V instead of 19V. I found a shorted coil and injected 1v. TPS65993 is heating up. I powered it through the rectangular plug, not through USBC. It is possible that this integrated circuit has burned out. I can't find a datasheet. TPS65994 can be found at Mouser but I don't think it is a good replacement. This TPS65993 is PD controller.Thanks. Motherboard code is HLG30 LA-L916P.
          05-06-2025, 01:37 PM
