[BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
  • AgustinLorenzo
    • Oct 2023
    • 6
    • Alcala de Henares
    Hi boys,
    This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
    Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
    Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
    After having carried out all the frequent internet steps (Win + B, USB recovery) we have not achieved anything, arriving "I think" to the conclusion that for some reason the BIOS was corrupted or that version published by HP has some error.
    I have fixed many software/hardware problems but never with this one, that is why I have already done the following:
    - Buy a USB programmer in order to reprogram the BIOS (https://www.amazon.es/gp/product/B07RKXSMKH)
    - Check the model of my BIOS chipset, Winbond brand and model 25Q64JVSIQ
    - Check motherboard model: CSL50/CSL52 LA-E791P Rev:2.0 and date: 2017-07-18
    - Find out BID of the motherboard which is 08328
    Things I still need to do:
    - Extract DUMP from my current BIOS, I am waiting for AMAZON to deliver my package.
    If you can help me, I would be delighted.
    If I have made a mistake, let me know and I will try to correct it immediately.
    Regards, Agustin
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: [BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
    Originally posted by AgustinLorenzo
    Hi boys,
    Regards, Agustin
    MAKE SURE THIS BEFORE DEMANDING ANY BIOS FILE FOR NO POWER, NO DISPLAY, OR PASSWORD RELATED
    BRAND & MODEL NUMBER :-
    SERIAL NUMBER / SERVICE TAG:-
    MOTHERBOARD PART NO:-
    COMPLETE BIOS BACKUP
    IF 1 OR MORE THAN 1 BIOS FILE ATTACHE ALL
    PROBLEM/ISSUE :-
    IF PASSWORD THAN PASSWORD IMAGE:-
    • AgustinLorenzo
      • Oct 2023
      • 6
      • Alcala de Henares
      PROBLEM/ISSUE :-
      Hi @qayyum786,
      Sorry, about that i am new in the forum, i share the detail specified:
      BRAND & MODEL NUMBER: HP Pavilion 15-BS521TU
      SERIAL NUMBER / SERVICE TAG: CND7440RSK
      MOTHERBOARD PART NO: CSL50/CSL52 LA-E791P Rev:2.0 and date: 2017-07-18
      COMPLETE BIOS BACKUP: At the moment, i don't have a backup file, buy I buy a programmer USB to extract them.
      PROBLEM/ISSUE: It does not show video on the screen after bios update but it does turn on all the LEDs (M.2, battery charge and device status)
      Thanks.
      Regards, Agustin
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Hi @qayyum786,
        Thanks.
        Regards, Agustin
        so we are waiting for the programmer i guess you buy a ch431
        even if i give you the bios file (as per your bid you have given above) it will be meaningless until and unless you don't get a programmer in your hand to program the bios in your laptop
        just ping us here when you will get a programmer some one will send a working bios file for you
        • AgustinLorenzo
          • Oct 2023
          • 6
          • Alcala de Henares
          Hi @qayum786
          My BIOS chip is Winbond 25Q64JVSIQ (I saw that it was read/write compatible with my chip) and I buy a CH341A with clip for SOIC8 SOP8 (to avoid desoldering/soldering) in Amazon (It should arrive in a few hours).
          I will notify you to have the programmed and the backup of the corrupt BIOS
          Regards, Agustin
          • AgustinLorenzo
            • Oct 2023
            • 6
            • Alcala de Henares
            Hi boys,
            After few hours..i get a backup of my actual BIOS ROM, the latest BIOS RAM flashed is F.73.
            I used to extract my current BIOS "NeoProgrammer V2.2.0.10" which I found on this forum.
            Regard, Agustin
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Hi boys,
              Regard, Agustin
              BIOS guides, methods, resources and tools
              https://www.badcaps.net/forum/showthread.php?t=103526
              6. Finding bios update packages
              6.1.8 HP
              See:
              [Guide] How to extract ready for programming dump from HP update executable file
              https://www.badcaps.net/forum/showthread.php?t=121948
              https://www.badcaps.net/forum/showth...51#post1261151
              Originally posted by SMDFlea
              When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
              DMI and Windows key: 210000 - 21103F
              Become a Badcaps supporter
              Thanks to all supporters.​
              • mitchw
                HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                by mitchw
                Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                04-29-2025, 03:45 PM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • Technodoc
                ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                by Technodoc
                Asus laptop G614JZ-N3012W Rog Strix with i7
                Mainboard G634J-PMV-VGT
                6050A3441302-MB-A01
                2023-02-10
                Power button works okay....power light goes on
                Red "bottom" leds go on
                Charging led works
                Fans do not spin, capslock key does nothing, screen stays black
                I would like to program the bios again, to rule out a corrupted bios.
                However I run into a size error
                The bios chip is a Winbond 25R256JVEN
                Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                02-24-2025, 04:46 AM
              • il60
                zbook 17 g3 Crach During Bios update, now black screen (dump bios provided)
                by il60
                i have an zbook 17 g3, i updated the bios, but the computer crash during update
                now black screen
                may you repair my bios in order to have work bios but keep all hp information (DMI sn..)
                dump attached,
                big thank you !!!...
                06-09-2023, 09:51 AM
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
