How can I test non-polarized capacitor?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread, but there is no Tan(δ) in the characteristic entry(page 135) which is essential for ESR calculation.
    Is this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) defective?
  • R_J
    • 9610
    Usually, a cap with that rating in a crt tv is in the horz. yoke return path, if it was bad, you would likely have a narrow picture.
    • chth96
      • Nov 2022
      • 118
      • indonesia
      Is it means that this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) has nothing to do with symptoms of no display after I heard sound of inrush of current to TV?
      • R_J
        • 9610
        Thats what I suspect, can you post the make and model or service manual? or maybe post some pictures of the board.
        • chth96
          • Nov 2022
          • 118
          • indonesia
          partnumber on the surface of main PCB and small PCB is
          MC-7CA(MAIN) 6870VM0056C(6) 980424 L.W.G(0)
          MC-7CA(CPT) 6870VS0167A(1) 971014 K.J.B(0)
          and model number of This LG CRT TV is CN-29H3
          Frankly speaking,I posted a thread about this CRT TV in the reddit forum.But It seems that there is no way to find the culprit of no display symptoms.
          https://www.reddit.com/r/Electronics...6707_regulator
            • 31265
            does the iinside of the tube neck glow?
            • chth96
              • Nov 2022
              • 118
              • indonesia
              I have desoldered PC817 Optocoupler from PCB of this CRT TV and tested it by following below youtube tutorial.
              https://www.youtube.com/watch?v=SPSwvVpMrvc
              I confirmed that a led light turned on, But unfortunately, When I measure its resistance of pin 3 and pin 4 with10k ohm range of analogue meter, I saw that It display two reading of low resistance when checking both way.
              I think that following youtube tutorial spoiled PC817 Optocoupler, So I need to find any local store where sells it.
                • 31265
                you can find optocouplers inside almost every switching psu including ones in lcd monitors
                • chth96
                  • Nov 2022
                  • 118
                  • indonesia
                  I purchased LITEON LTV817 D grade. But PC817 Optocoupler, which was defective, was C grade and made in Sharp corperation.
                  Is it Okay to replace C grade PC817 from Sharp corperation with D grade LITEON LTV817?
                    • 31265
                    maybe - try it
                    • chth96
                      • Nov 2022
                      • 118
                      • indonesia
                      I finally soldered LITEON LTV817 D grade on the PCB circuit of 29inch CRT TV and switched on this CRT TV.
                      It still displayed black screen. And It seems that it doesn't glow inside of the tube neck at all...
                      and Moreover, After switching on I measured voltage of this big capacitor(160v 100uf) on the cold side,which seems to be B+ filter capacitor,It was measured only 37-38 voltage in DC Voltage mode of analogue meter,But before I replaced opto-coupler with LITEON LTV817 D grade,It was measued nearly 45 DC voltage..
                        • 31265
                        low B+ could be a short circuit on the HV side,
                        if you look at the trace for B+ you usually have a link or inductor that couples the HV section,
                        you can desolder that and put a 40w 240v lamp across the B+ cap as a load - then test it again.
                        • chth96
                          • Nov 2022
                          • 118
                          • indonesia
                          Thank you very much for reply.
                          I roughly draw most of flyback transformer's soldering point and its nearby components on the circuits.
                          I noticed that B+ soldering point is coupled to three carbon resistor(R432,R437,R831) and C829 is the big capacitor.
                          Should I isolate B+ soldering point by desoldering these three carbon resistor(R432,R437,R831) from circuits In order to connect 240v lamp and test it?
                          And where should I solder 240v lamp on the bottom of PCB?
                          Click image for larger version  Name:	scan0008.jpg Views:	0 Size:	1.31 MB ID:	3296825
                            • 31265
                            is this similar?
                            check the H46 schematic - L853 inductor left of the transformer
                            or H90?
                            lift R402
                            • R_J
                              • 9610
                              This is likely the schematic. I would replace the small electrolytics in the power supply primary, they are likely weak. C812, C810, C811
                              This tv power supply is always running when it is plugged in so those caps take a beating. C810 is right next to R807 which would cook that poor electrolytic
                              • chth96
                                • Nov 2022
                                • 118
                                • indonesia
                                Thank very much for reply.
                                there is no inductor left or right to the transformer.
                                I saw H46 or H90 schematic which you have attached, But it seems that it is totally different to the circuits which I tried to repair.
                                And I saw MC-7CA schematic and at least It is somewhat similar to STR-S6707 area in the circuits.
                                You can compare STR-S6707 area in the MC-7CA schematic to my drawing of circuits which contains resistor and capacitor near STR-S6707.
                                Click image for larger version  Name:	scan0001.jpg Views:	0 Size:	2.68 MB ID:	3297034
                                I already have measured ESR ohm value of all capacitor with ESR meter(MESR-100) and checked most of diode and carbon resistor in the STR-S6707 area and I replaced C810(25v 470uf Korea chemicon KME) and C811(25v 220uf samwha RG) which has higher ESR ohm value(C811 was measured over 70 ohm)
                                But it won't repair black screen symptom..
                                • chth96
                                  • Nov 2022
                                  • 118
                                  • indonesia
                                  The strange thing is whenever I measure the DC voltage of pin#9 of STR-S6707, It is measured 6.4V.
                                  As far as I know,It should be measured at least 7.6V in order to go On-State Voltage.
                                  I doubted any diode near STR-S6707,So I checked it using analogue meter(x10 ohm) But It showed only one reading with the correct and opposite polarity of probe.
                                  • R_J
                                    • 9610
                                    What is the voltage across C812? it needs to be at least around 9vdc to supply the regulator transistor Q800 collector. Q800 base should measure 7.5vdc, if not ZD808 may be leaky and not zenering at 7.5vdc I would have also replaced C812
                                    If Q800 collector is over 9v and the base is 7.5v and the emitter is only 6.4v, Q800 may be bad
                                    • chth96
                                      • Nov 2022
                                      • 118
                                      • indonesia
                                      I just have measured DC voltage of C812 by placing red probe to positive terminal of C812 and placing black probe to negative terminal of C808 in HOT area(400V 470uf the biggest capacitor in the circuit).
                                      It was measured 10.8DCV.
                                      And I measured cathode of ZD808,It was measured 7.1DCV and Q800(C3852A) base was also measured 7.1 DCV.
                                      Q800(C3852A) collector was measured 10.8DCV.and pin#9 of STR-S6707 was measured 6.4DCV.
                                      I desoldered C812 and I check it with LCR T4 meter. Its capacitance was still within 10% tolerance(23uf) and Its ESR value was lower(0.5 ohm) than reference value.
                                      By the way it was written B.75 on the surface of ZD808 zener diode.
                                      Is It Okay to purchase any zener diode which has specification of 7.5V?
                                      • chth96
                                        • Nov 2022
                                        • 118
                                        • indonesia
                                        I replaced ZD808 zener diode with 1N4737,But it won't repair black screen symptom,and there is no difference between these zener diode in measuring cathode voltage(7.1Vdc)
                                        I think that I need to connect a 40w 60w bulb to B+ soldering point of Flyback transformer,But I don't know the process to substitute for the Flyback's B+ Load with a blub in detail.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • Agent24
                                          Dick Smith Q-1760 linear power supply filter capacitor question
                                          by Agent24
                                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                          It has at least one problem.
                                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                          I have already ordered a replacement potentiometer, so that's not an issue.
                                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                          All are CapXon...
                                          10-21-2025, 05:39 PM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
