Picking long life capacitor replacements?
  • slybunda
    • Feb 2012
    • 139
    to pick some good quality capacitors for long lifetime do i just go to mouser, rs etc and select the capacitance and voltage then sort by the highest number of hours and pick the caps that have the highest number of lifetime hours?
    • 31281
    almost.
    you need to know the difference between regular, low and ultra-low esr and when to use each type
    in most cases you can just throw ultra-low esr caps in, but there are some situations where that wont work.
    • slybunda
      • Feb 2012
      • 139
      Ok cool, noticed that wurth brand caps seem to be rated way higher than other caps for lifetime
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        Picking one that is a good amount above requirement voltage (say 25v for 12v instead of 16v) increases life too, but there is more information involved to really determine if this works, and it's not just voltage, probably ripple too, but I'm not sure about uF
        • slybunda
          • Feb 2012
          • 139
          From what i read if selecting a higher voltage cap and the cap never reaches its rated voltage then something happens to it where it cant be reformed and looses capacitance?
          • lti
            • May 2011
            • 2557
            You don't want the cap to actually hit its rated voltage. There should be some margin.
            I've heard that caps will fail faster if you run them too far below their rated voltage, but I haven't ever found any official documentation to confirm or deny that.
            • quickname
              Cyberpower 1500AVR UPS repair
              by quickname
              I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
              Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
              I decided to verify that the batteries were...
              11-12-2023, 09:57 AM
            • szreder6
              HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
              by szreder6
              Hello guys,
              I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
              What I did:
              - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
              As far as I know the laptop was in another service center...
              11-22-2024, 05:17 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • ajdrenter
              Picking caps for Antec SU-380
              by ajdrenter
              In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
              https://www.badcaps.net/forum/showthread.php?t=14159
              It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
              05-13-2023, 10:40 AM
            • fr0n1k
              FPW50_LA-H323P long boot, NEED to clean ME?
              by fr0n1k
              Hello. Recently i've got HP 15-dw0005ur with too long boot - near 1 minute before HP logo appears. Am i correct, that this problem reflects to ME and i need to clean it? Can you please help me and share a tool or guide how to do that?...
              11-12-2025, 02:13 PM
