FPW50_LA-H323P long boot, NEED to clean ME?
  • fr0n1k
    • Feb 2020
    • 12
    • Russia
    Hello. Recently i've got HP 15-dw0005ur with too long boot - near 1 minute before HP logo appears. Am i correct, that this problem reflects to ME and i need to clean it? Can you please help me and share a tool or guide how to do that?
    • 22099
    ME guides https://www.badcaps.net/forum/troubl...22#post1622422
    Please post the laptop serial number and motherboard model number.
    • fr0n1k
      • Feb 2020
      • 12
      • Russia
      Motherboard number is FPW50 LA-H323P and my SN is CND01069WJ
      • LBTT1121
        • Nov 2024
        • 1185
        • Việt Nam
        TRY
        • fr0n1k
          • Feb 2020
          • 12
          • Russia
          Originally posted by LBTT1121
          TRY
          Nothing has changed, everything is the same(
          1 minute before HP logo appears..(
          • m1ch43lzm
            • Mar 2019
            • 1032
            • Peru
            Try BIOS extracted from HP website, DMI + Win key inserted
            HP Notebook - 15-dw0005ur
            BID 085EF
            BIOS ver. F.31
            S/N CND01069WJ
            DMI + Win key 320000-32103F
            First boot takes some time (initialize ME and RAM training), after restart it should boot quickly
            • fr0n1k
              • Feb 2020
              • 12
              • Russia
              BID 085EF
              BIOS ver. F.31
              S/N CND01069WJ
              Thank you so much for your desire to help.
              After flashing this rom i've got Flashing boot block progress bar.
              It seems to me, that backlight now activates faster, but after that.. Still 1 or more minute before HP logo appears.
              Manufacturing Programing Mode is in unlock mode.
              And the strange thing is, that Caps lock button responds before hp logo appears, as i understand correctly, laptop fully initializes, but for some reason boot or bios options are delayed
              UPD. I have flashed bios from this thread - https://www.badcaps.net/forum/troubl...89#post1826789 , and have got nearly the same result - When i press power button, 5-7 secs before LCD backlight turns on, after that caps lock button works, but HP logo appears / boot option / bios option 1 or 2 minutes later..
              Have tried to change ram, remove wi-fi module, Any idea?
              • fr0n1k
                • Feb 2020
                • 12
                • Russia
                I have noticed, that it boots fast after persoming reboot from windows, but if i turn laptop off - boots 1 or more minutes.
                Same result with Self-test.
                • m1ch43lzm
                  • Mar 2019
                  • 1032
                  • Peru
                  Do you get CMOS Reset 502 error if you power on after being powered off?
                  If yes, check +RTCVCC, should be 3V, page 13 of the schematics
                  Schematics here
                  https://www.badcaps.net/forum/troubl...chematic-or-bv
                  If not, a faulty HDD/SSD can cause a boot delay, remove HDD/SSD and test again
                  The BIOS i uploaded has Manufacture Programming Mode unlocked, you can use HP BCU to lock MPM
                  • fr0n1k
                    • Feb 2020
                    • 12
                    • Russia
                    Schematics here
                    1) i Have CMOS Reset 502 error only after battery remove, with battery installed - no problems or CMOS error.
                    2) Laptop perofms same, with or withour SSD. Have tried several, that 100% working and not faulty.
                    i have tried:
                    remove all flex cables (usb, keyboard, touchpad, touch buttons), different PSU, different batteries, several 100% working ssd's, many ram sticks, disconnect wi-fi module..
                    No idea
                    • cdma-india
                      Acer Commercial BIOS boot logo tool for TMP214-53
                      by cdma-india
                      REQUIRED Acer Commercial BIOS boot logo tool for TMP214-53
                      I WANT TO CHANGE STARTUP BOOT LOGO ANY ONE HAVE ABOVE TOOL OR ANY EXACT LOCATION WHERE BOOT SPLASH SCREEN LOCATED?
                      THANKS
                      02-27-2023, 09:27 AM
                    • burbutsalos
                      55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
                      by burbutsalos
                      Hello ,
                      The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
                      If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
                      Any ideas what to check?...
                      12-12-2023, 06:06 AM
                    • privato89
                      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                      by privato89
                      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                      Let's begin:
                      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                      03-26-2024, 06:37 AM
                    • rex98
                      HP DMI Tool
                      by rex98
                      HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                      DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                      The DMI Tool given here are for personal use only.
                      DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                      You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                      from it, and that you please credit the author...
                      07-02-2025, 05:51 AM
                    • hinisa
                      Xiaomi router freezes at boot after re-capping
                      by hinisa
                      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                      07-08-2023, 05:58 AM
