My First Recap
  • Duffycoug
    • Mar 2007
    • 4
    My First Recap
    Well, thanks to this website, and specifically this forum, I just recapped my Gl_VE HP 533C motherboard after the caps blew. I had no idea that was the problem until I ran across this site. That computer was just sitting there waiting to be thrown out...lucky, that never happened. I ordered new caps and took the board out of the case.
    I must say I am 99% sure I did an ultra hack job according to this website, but it fired right up and is working perfectly now!!! I used a 30W needle tip soldering iron and used a stainless steel needle to clear the solder out of the holes. I wasn't delicate to say the least, but like I said...it's working great!
    Anyway, thanks a ton to everyone here and to this website....I never even had to post any questions due to the extremely informative "How To" Forums that were already posted.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: My First Recap
    Glad it worked! post some pics. I like looking at other people's handywork.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Re: My First Recap
      And let us know where you found SS needles!
      • Sudum Gumudu
        • Sep 2005
        • 97
        Re: My First Recap
        I use a sewing machine needle with the eye cut off, secured in a piece of electrical block. Works like a charm. Sewing machine needles are usually made of stainless steel.
        • Duffycoug
          • Mar 2007
          • 4
          Re: My First Recap
          That's what I used...a sewing needle.
          • Spacedye69
            • Nov 2005
            • 698
            • US
            Re: My First Recap
            Hah! Thanks, I did not know that.
            • tazwegion
              • Jun 2006
              • 444
              Re: My First Recap
              Well give us a look eh? we all learn through experience, feedback & guidance
              A 'superfine' jeweler's screwdriver works as well (if not better) than a sewing needle in my experience @ clearing out pcb perferation/mounting points
              Viva LA Retro!
              • Grusin
                • Mar 2007
                Re: My First Recap
                You can use a very fine drilling bit, e.g., 1/32", instead of sewing needles.
                • tazwegion
                  • Jun 2006
                  • 444
                  Re: My First Recap
                  Using a drill to clear out solder opens you up to all manner of strife as you'll likely remove more than mere solder, rendering your project ruined
                  Viva LA Retro!
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: My First Recap
                    i know a machine shop owner who would likely shoot anyone who he caught drilling on boards.an idiot "tech" did that to a one of a kind unobtainium board in a machine.
                    he made quite a mess of it.
                    he got fired and when i got it running again the owners wallet was a lot lighter.
                    • Grusin
                      • Mar 2007
                      Re: My First Recap
                      Gentlemen
                      I said drill bits, not using a drill.
                      Bcos "solder" is soft; one can gently turn the bit (using his finger)a few rounds & make thru the thin layer.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        Re: My First Recap
                        Originally posted by Grusin
                        Gentlemen
                        still not worth the risk.a good sharp bit will still tear out the copper thruhole even with finger pressure.
                        maybe i am overcautious as much of the stuff i work on is both expensive and hard to replace.a mobo is a small loss to learn your lesson by.
                        • Duffycoug
                          • Mar 2007
                          • 4
                          Re: My First Recap
                          I'd like to post some pix for you guys, but it's already back in the tower...I should have thought of that before I re-installed it. Anyway, it's been about 10 days and I've had zero problems with the computer...it's running perfectly! Thanks again to everyone here, this is truly a fantastic site....I bet there are alot of others out there who don't realize the caps are their problem.
                          • Duffycoug
                            • Mar 2007
                            • 4
                            Re: My First Recap
                            I can't believe it's been over two years since I did this......IT'S STILL WORKING PERFECTLY AND HAS NEVER AGAIN RANDOMLY TURNED ITSELF OFF!! Wow, this was such a great find this forum, thanks again you guys!
                            • shadow
                              • Feb 2007
                              • 732
                              Re: My First Recap
                              Good to hear Duffycoug.
                              And by the way, welcome back to the forums!
                              I see it has been a while since you have been posting.
                              • yanz
                                • Nov 2004
                                • 910
                                Re: My First Recap
                                yea, glad to know that ur board is still working years after recapping
                                thx also for reporting
                                days are so short when you actually do something..
                                  ASUS P5GC-MX motherboard recap
                                  by momaka
                                  Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                  This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                  So here is what the motherboard looked like with its original caps:
                                  CPU VRM area up close…...
                                  01-27-2021, 11:59 PM
                                  no-name Radeon 9600 XT recap and cooler
                                  by momaka
                                  I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                  This one was actually suggested to me by ChaosLegionnaire....
                                  11-06-2020, 07:54 PM
                                • harp
                                  Needle protection for small current instruments
                                  by harp
                                  Just want to know is there some common method to protect needle from crashing to end, if the meter is galvanometer or microampermeter with both side movement, needle in center?
                                  If it comes to fast and high unbalance on bridge, the needle was smash and bent. Some electronic circuit might help but it should not interference with measurement if value is in ok range....
                                  01-16-2023, 12:11 PM
                                • varunviolin007
                                  Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                                  by varunviolin007
                                  Hi guys,
                                  I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                                  I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                                  Looking for someone experienced with older PC boards who uses...
                                  07-29-2025, 11:53 PM
                                • Foetuss
                                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                  by Foetuss
                                  Hi all
                                  Hope this is in the correct place.
                                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                  Could use some double checking to see if I'm not doing something stupid .
                                  Pictures of the boards are attached.
                                  What I will be replacing with what : (planned)
                                  Soltek Golden ::
                                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                  01-18-2025, 11:44 AM
