Lower voltage cap on PSU?
  • dcapper
    • Dec 2013
    • 496
    I think I know my answer but I thought I would ask just to make sure. I have a Samsung LN-S3241D LCD TV. I want to replace all the Capxon capacitors. I have all the caps to replace them but the missing one. The one on the board is small and it's 68uf 63v. I have 2 lying around that I would like an opinion on. I have a 68uf 25v which is larger than the one on the board. I also have a 68uf 75v one too but it's pretty big and I don't know if it will fit. I'm assuming the 25v one has too low of a voltage rating correct?
    Edit: They are both 105C
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Lower voltage cap on PSU?
    25V is probably too low, 50V might even be too low. you'd need to measure the voltage going across that cap while in operation. If I was you, I'd use the 75V cap as long as it doesn't go too tall to clear the case, and the increased ESR shouldn't matter
    • dcapper
      • Dec 2013
      • 496
      I thought so too. I think I should have room but I'll have to check. I probably don't need to replace it but this is the second Samsung I've had that had faulty Capxon caps. One is bulged on this board and another is squealing.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Oh, CapXon, that explains it. They should all be replaced if you don't want to be doing this again.
        • dcapper
          • Dec 2013
          • 496
          I found a 105C 68uf 63v Nichicon cap on a board that I wasn't using. It's the right size so all the Capxon's will be gone.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Perfect! What series is the nichicon cap?
            • dcapper
              • Dec 2013
              • 496
              It says PW(M). That make sense?
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Perfect replacement
                • dcapper
                  • Dec 2013
                  • 496
                  I ordered the rest from Simoncapacitor on Ebay. He gave me a kit for my Samsung computer monitor and its been working great ever since, so I'm sure it will be good in the tv psu.
                  • Adenitz
                    Electronics failing when supplied with lower voltage
                    by Adenitz
                    Hello guys,
                    recently I watched Richard's video on YT (Learn Electronics Repair channel) with an explanation why lower input voltage than rated can also kill electronics components.
                    The vide can be shown here.
                    Now, I would like to learn more and I'm not sure that I understood exactly why this is happening.
                    It is clear to me that PWM chip will keep MOSFTES switched On longer (duty cycle is longer) and that they will dissipate more heat. I think this is not the main reason because MOSFET can probably work switched on for a long time. It is also possible that output...
                    12-26-2022, 12:45 AM
                  • Instafixx
                    Macbook A2179 820-01958
                    by Instafixx
                    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                    I checked the Power Sequences below and found this -
                    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                    05-20-2023, 05:19 AM
                  • Fernon@Repair
                    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                    by Fernon@Repair
                    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                    VCCIO voltage ok
                    VCCSA Voltage OK
                    VCCPLL Voltage OK
                    Ram Voltage ok
                    RamVTT OK
                    VPP 2.5 OK
                    But No Core Voltage
                    and i want to this vrm ic datasheet or pinout (ISL69269)
                    anyone have this ic pinout voltages?...
                    06-25-2025, 07:19 AM
                  • electron_jj
                    Panasonic TH-L42D25A checking the PSU output voltage
                    by electron_jj
                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                    08-29-2021, 08:13 AM
