I hate you guys -- I guess ignorance WAS bliss!
  • handyrandyrc
    • Feb 2007
    • 8
    Okay, I really don't HATE you, but you've made my world a WHOLE LOT bigger now! Sheeeeiiit!
    I have had stability problems with my PC for months now, lockups, blue screens, error messages come up "Windows has recovered from a serious error". I get explorer.exe error messages. I've reloaded Windows and have the same symptoms. Someone on another forum asked about capacitors on my motherboard, and recommended THIS site. I now feel like I bought the biggest lemon components I could have possibly purchased.
    Gigabyte GA-8IPE1000-G motherboard - Intel 865PE chipset
    13 Supacon Capacitors, and a couple swollen -- at least they used Big Nichicon ones for the main CPU power.
    Geforce 6600GT AGP card -- full of Lelon caps
    Antec Smartpower 350Watt - Full of fukkiyhu caps -- some swollen
    So now I'm looking at replacing every one of these junk capacitors, and reeling from the amount it might cost me. Happy that I know what's likely causing my problems, but I feel like I need to fix "all three" components (video card, power supply, and motherboard) before I feel like I can trust any one of them to be stable.
    Yay for you guys! I will be spreading the word. Lots of AWESOME information here folks!
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2662
    • oooo ess aaaaaaaaa
    Re: I hate you guys -- I guess ignorance WAS bliss!
    First off....welcome.
    sorry you've run into the problem of badcaps. there is a wealth of info here. biggest part of taking care of the problem will be your soldering skills. i know for me, i like replacing components. electronics nowadays is throw-away so its nice to resurrect stuff.
    good luck in your quest. with all the brains that hang out here, you should be able to get any question answered.
    stick around and have some fun too.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • stevo1210
      • Oct 2006
      • 4156
      Hello handyrandyrc,
      I Have the exact motherboard and the caps around the CPU are also Nichicon branded, my Nichicon caps are the HM(M) series and probably the same as yours, but it is quite odd for me to hear that you have Supacon capacitors everywhere else. I have KZG caps instead.... What revision series is your motherboard?? My board is REV.3.0.... maybe they changed caps with the future revisions??
      So far I haven't had a single vented caps on this motherboard and it is rock solid in terms of stability.
      Thanks.
      • Fizzycapola
        • Oct 2006
        • 423
        It's not full of Fuhhiyu caps, just the main 2 caps and the caps on the rails.
        If you replace the PSU caps I recommend maxmum safety precautions, beware parts which shouldn't have electric in them may do. I wore thick rubber gloves and rubber boots when I partially recapped mine.
        Rubycon Rubycon Rubycon
        • gonzo0815
          • Feb 2006
          • 1600
          Well, simmply unload the PSU`s bigger high voltage DC capacitors by shorting them with an insulated screwdriver. or better with an powerresistor.
          Before that, just pull the cord when the system is runing, so in most cases this alone will ashure discharged caps.
          After that, there is no hazardous voltage left.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            if those nichicons are hn or hm series replace them too.
            there were some bad batches.unfortunatly its unclear when or how many bad parts were made.
            replace now and avoid a repeat.
            • stevo1210
              • Oct 2006
              • 4156
              I havn't planned to recap those Nichicon HM (M) caps around the CPU yet since my Nichicon HM (M) caps have lasted for more than 2 years without bulging.... yet.... Maybe i'm not affected by the HM series issues??.
              Those Nichicon caps also have to currently withstand the heat and power from my 3GHz P4 Prescott CPU, but so far they are holding up OK.
              I'll have to wait and see the future results though.
              Thanks.
              • Galvanized
                • Mar 2006
                • 468
                Welcome handyrandyrc!
                This is a good, quick read to pass on https://www.badcaps.net/faq/ Crappy PSU current does have an impact on motherboards and cards.
                • handyrandyrc
                  • Feb 2007
                  • 8
                  Thanks for the tips, gents. I hope my 'leet soldering skills are enough to get me through. Have a nifty ceramic element soldering iron I bought for soldering battery packs together when I used to do RC Cars for a hobby. I'll put the baby chisel tip on it, but I hope it's good enough for the job. I'm kicking myself that I didn't know to buy a "grounded" iron back when I bought it. I spent probably 40-50 bucks on this iron -- while it's not an Ungar or a Hakko, and doesn't have a power supply, it's always done whatever job I've needed it to do -- light or HEAVY. Link to my Inland iron:
                  http://store.allstainedglass.com/inincersolir.html
                  The Nichicon caps are HM(M) series, so I suppose I'll just replace 'em all to rule out anything. This Gigabyte board is a Rev. 4.0, so perhaps they changed to Supacons for the 1000uf caps with that revision.
                  I used to convert PC power supplies to be a DC power supply for my RC battery chargers. I've mounted banana plugs in the power supply casing and everything for a tidy little job. I've even wired up 3 power supplies' 5v outputs in series to give me some serious 15v output to run multiple RC abttery chargers. So I've played with those nasty big caps -- always an impressive arc on a screwdriver when you discharge those! Thanks all for watching out for me. I'll give a review of my progress. Maybe I'll even haul out the camera for some hot close-up action.
                  • gdement
                    • Jan 2007
                    • 690
                    I wouldn't worry much about the ungrounded iron. IMO the whole esd thing isn't nearly as frequent a problem as people make it out to be. It's a convenient magical explanation whenever anything doesn't work. Since you'll only be soldering on capacitors, it's very unlikely you'd do anything that damages a chip, except through heat. I soldered many boards with an ungrounded iron before getting a newer one which happens to be grounded.
                    • zmeutul
                      hi guys i need bios for 6-77-NP50PNJY-D02B-3C
                      by zmeutul
                      hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
                      09-26-2024, 01:55 PM
                    • ferah831208
                      by ferah831208
                      03-18-2025, 01:18 AM
                    • Mirenia
                      Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                      by Mirenia
                      got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                      The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                      If this happened once, then the laptop only runs for a few minutes until restart.
                      This happens regardless while staying in windows or uefi or in a linux environment.
                      At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                      01-05-2025, 05:15 PM
                    • Capacitorial
                      Powersupply has all the voltages - Monitor still no power
                      by Capacitorial
                      Hello guys,
                      I have a Philips 240B7QPJEB. The monitor seems completely dead.
                      I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                      On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                      The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                      The weird thing is, that the Power LED is powered over the TCON board.
                      On The TCON...
                      12-28-2024, 02:12 PM
                    • testaccgta
                      Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                      by testaccgta
                      Hi, everyone!
                      I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                      I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                      09-01-2024, 08:24 PM
