My work throws away (pays to recycle) our broken obsolete electronics. I grabbed a couple of NEC monitors and decided I would see if I could fix them. They all show bad caps. I replaced the caps on two and they work great and gave them out at work so they could use dual monitors. Anyway I opened another NEC (rebranded Benq) and noticed the following 3 caps. The two on the left are 1000uF but the silver only says 1000 16v. I assumed this was 1000F but I wanted to get your opinion since I don't want to put the wrong type in. Here is a pic of the caps with an insert of the same type of cap elsewhere on the board. Sorry if pic is too large.
is this 1000F or 1000uF (pic)
Re: is this 1000F or 1000uF (pic)
Is that silver cap a Nichicon HD? They are pretty good.... I don't know why that one is leaking....Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - AnonymousComment
That Nichicon HD will be fine, but you can use a larger can-size cap with higher voltage if you have the space, maybe a Panasonic FC 1000/25v instead. There's also a fair chance that every Lelon on the board will also fail eventually, so you might as well replace them now.Comment
Thanks I replaced all 3 and now the monitor works. I don't have enough caps to replace all of them but I will order them Monday. Looks like someone will be getting dual monitors at work in about a week.
This one was a NEC Multisync 1720M (Made by Benq)
they can have an oval. i have never figured that one out though, nichicon appear to only use the oval on the HD series?All of the pics I found of actual Nichicon HD's had "Nichicon" where this has an oval.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
