Re: Why desolder the old?
You can do it that way provided you keep the leads full length to avoid
transmitting heat into the cap body and you pull the leads through (with
long nose pliers with breaks for each few millimetres achieved to allow
built up heat to dissipate - pushing the leads through didn't work for me -
it just bent the leads alot).
Once the solder is molten it's reached it's thermal capacity and any more heating will force the heat to start flowing into sensitive parts of the board at
a component killing 450°C and the capacitor body destroying them through heat damage instantly.
As long as you don't cause heat damage to the board or capacitor there
shouldn't be any problems. Of course Troda's advice bypasses these risks.
The other technique of just ripping off the capacitors and soldering new ones
onto the existing leads, even I won't condone that though, leads must be
as short as possible for maximum performance. Although I admit
I've been having thoughts of placing component sockets on the board so I
can simply slide out and slide in different capacitors on the fly, to see which capacitors give the best performance.
All said, I don't suggest you listen to me over Troda's, he's a electronics
professional and I can't read circuit diagrams designed for children without
suffering brain failure.
