Why desolder the old?
  • Grefven
    • Nov 2006
    Why do I need to completely desolder and clean the hole in the MB when I try to recap my board (Asus P4PA)?
    The simplest way must be to simply "destroy" the old capacitors, keeping its leads on the motherboard and then solder the new capacitor on these leads?
    Tell me why/why not to do this?
    I have tried on another board (not an MB) to do this, and I found that it was possible to "pull" the old capacitor straight up and the leads would then slip out of the capacitor and left there (somewhat trimmed) to accomodate the new capacitor.
    Using this technique I would not need to have an iron at 450 degrees, and save a LOT of time and anxciety of damaging the board in the desoldering process.
    Cheers from Sweden and a Dude who's preparing for his first cap-job.
    / Tomas
  • arneson
    • Sep 2005
    • 1267
    Re: Why desolder the old?
    Heres my analogy, I blow a tire and I'm lazy, so I put the donut on the car and and leave it like that.
    It still goes but it looks crappy and it's not safe.
    Jim
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      1
      it looks crappy
      2
      stray inductance from the long leads.
      3
      it looks like shit.
      spend a few bucks and get proper tools that will allow you to do it right.
      they can pay for themselves fast if you do a bunch of boards over the years.
      you might even turn a profit if others around you need such work done.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        its not that difficult anyway as long as you follow the guidelines, it just looks difficult and dangerous.
        most important
        - a hot enough soldering iron
        - practice first
        - dont work when you are tired or angry
        i remember one of our members asked the same question a while back. but in fact he went on to recap many motherboards properly and did impressive work.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          I'm just going to pretend I never saw this thread....
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            hey now, todays are tomorrows recappers
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Actually, off the record.... I did do that once.... I had a server go down (VP6 with bad caps), and I didn't have time to remove the board and do it right (that server being down would have left about 20 websites down too), so while I waited for a replacement board, I pulled the couple bad caps off the board and soldered some used ones I cannibalized off another board onto the leads sticking up, soldering them with the board and hardware still in the case... It actually held for about a week, until the new board arrived. I swapped out the boards during off-peak time, and then recapped it the right way. As an emergency fix, it worked, but I certainly wouldn't recommend it.
              Team : 49813
              Join in!!
              Team Stats
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Well, don't want to toot my own horn.... https://www.badcaps.net/forum/showthread.php?t=1150
                Ludicrous gibs!
                • gonzo0815
                  • Feb 2006
                  • 1600
                  In motherboards, the leads of caps are very short. If you destroy the cap, the remaining leads are a aluminium alloy, wich is not likely to solder without some good ultra sonic soldering iron. If you manage, to glue a new cap in there, there are very bad contact at the solder joint and very long leads. Those long leads add more reesistance and inductive reactance, wich in the end my slow down the transient response, increase voltage drop, cause ringing on the line and may cause cpu errors or vrm controler errors and generall unstable system behaivior. If you move the system, it is more likely to loose a cap, wich in the end gives more trouble than doing it once right.
                  As long as you can afford a high wattage iron with a standard chisel tip, it isn`t that hard to do it right.
                  • starfury1
                    • May 2006
                    • 1256
                    2nd all of the above.
                    It really becomes a self defeating exercise to not do it right.
                    gonzo0815 has more or less summed up all the technical reasons as to WHY
                    Grab your self a decent set of tools to do the job and practice on stuffed or old MB etc
                    its something you have to learn for your self like ridding a bike
                    There is nothing like having the right tool for the job too...so if you don't want to spend too much money get a china made knock off 701 desolder station.
                    (not that the china knock off is the best buy, but costs about 5 times less then a real quality unit Pace Hakko etc)
                    You will still have to take some time to learn how to use it thought anyway
                    Lastly doing it that way is not going to win you any friends
                    If you start recapping other peoples MB that way ...
                    You will only gain a bad reputation when their computers stop working go flaky and guess who they are going to call first
                    (and probably not want to pay you),
                    then possibly second and then never again.
                    Do it once
                    Do it Right
                    learn the procedure
                    Now where was that post about sticking down popped caps with sticky tape again
                    • yanz
                      • Nov 2004
                      • 910
                      i agree that we should do it the right way from the very beginning. still, i will always suggest for the new recapper to do it step by step. it's important to gather confidence for the project we do by seeing a progress. i usually bring back the mobo to full stable again after recapping caps on input and output vrm at first work. after knowing that my work is success (computer boot/post/memtest) than i recap all other places like memory area, agp, pci, near cmos etc and call it a day. i love perfect result.
                      i have no doubt this will 90% work. i once read overclockers.com's article abut this ghetto recapping. if you will recap it only one time in your life than go ahead. but if you'll recap more boards, it's important for yourself to do it right and build your skill with the right skill.
                      once u used to do it the wrong way, its hard to you to move to the bright side
                      • Fizzycapola
                        • Oct 2006
                        • 423
                        I broke off some capacitors on my recap. I only did it because I thought I couldn't
                        remove them using the iron and tip and had been informed this was an ok technique
                        on another website - this proved to be false imo - the remaining leads I found much
                        harder to remove and I was very worried about damaging the rings also - for hours
                        I pondered giving up because of this mistake. My iron was only 40 watt and the
                        tip was huge and not melting the solder - particularly around the back of the board
                        where the VRM is located - there was just too much solder sucking the heat away before
                        it could get hot enough to melt. Eventually I was able to remove the
                        capacitors by a combination of heating directly the metal rings both at the same time
                        and edging the lead one at a time. I remember moving the leads up and down, not just
                        downward, when desoldering, up and down motion and finishing in pulling it out a bit
                        seemed to leave the cleanest hole.
                        I believe the simplest and most time saving technique would be heating both rings
                        at once sliding out the failed cap and sliding the new one in (maybe pulling the leads
                        through with long nose pliers - I don't recommend pushing the cap through as like
                        I found I'd bend the leads out of alignment and eventually the lead would become
                        twisted and stopped sliding in - in the final picture of my recap you can see some
                        of the caps are a few degree's out of alignment where I'd used this poor technique -
                        the finished result doesn't look nearly as good as the pro's here), then trim the leads
                        as small as possible and apply a small ammount of solder at the ring to ensure a
                        good finish being careful that the solder doesn't bead or make a bad join.
                        This to me seemed both the quickest and least technical technique. I do own
                        flux and desoldering tools but I think you need a higher proficiency to use them well,
                        just sliding out the caps and sliding in the new caps is the fastest technique surely,
                        unless of course you don't want to remove the motherboard when recapping - but
                        this only takes under 1 little minute and is just extreme deplorable laziness.
                        Rubycon Rubycon Rubycon
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          Technique is a personal thing and also depends on tools. personally i work one leg out at a time, i have found this to be best, sometimes one leg is more difficult than the other. Doing it this way though, care has to be taken not scratch a trace on the front of the board with one lead which comes out first.
                          If i have some difficulty like if the cap must come out vertical for instance if there is no room to wiggle it then i grab the cap with a pair of fat pliers. care must be taken with those to put only similar stress on the board as if fingers were used to remove the cap.
                          Pushing a new cap through existing solder might stress the internals of a cap not to mention the lead port. you want the new cap to be heated for a minimum duration. i think it will be longer that way.
                          also the existing solder is probably not going to make a very nice and strong connection so additional solder will have to be added. having two different solders may not be the best idea, considering that one may be lead free and one not.
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            Hm why not? a little lead can only help there IMHO
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              yeah i am not sure about that part of my post
                              • grand_amatic
                                • Nov 2006
                                • 6
                                Well if not desoldering the old one is a problem...i have a question along those lines....why do I have to clean out the solder in the hole. Why cant I just heat up the solder pull the capasitor out and reheat the solder and put in the new capasitor..or does it not work like that.. You'll have to excuse my noobness.. i know you just talked about it but if the solder is hot it should just slide through causing no stress right?
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16956
                                  You're partly right there. I reflow the solder and pull the old cap out. I then clean the hole for the new cap. Without clearing or atleast reflowing the solder, you'll destroy the board before heating the hole up enough, holding the board, iron and the cap steady, and shoving a new cap in. No way around clearing the holes.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • gonzo0815
                                    • Feb 2006
                                    • 1600
                                    I am usually generouse with new solder when recapping. Sometimes i use some SnAg leadfree, but even then i usually ad some 0,5mm leaded solder to. Especially for desoldering i usually ad some of the 0,5mm leaded solder, to allow easy melting of the solder. On most boards i can`t get the old solder to melt untill i add some fresh ones with new flux.
                                    • grand_amatic
                                      • Nov 2006
                                      • 6
                                      I have a feeling im going to suck A$$. But i have an old board that IM going to practice on first....you have no idea how thankful I am that I found this site because I was blind going in and now I have some light on the subject. Thanks alot guys!
                                      • willawake
                                        Super Modulator
                                        • Nov 2003
                                        • 8457
                                        • Greece
                                        you will if your soldering iron is not hot enough
                                        otherwise you will do just fine
                                        • Prolog
                                          by Prolog
                                          12-01-2024, 08:27 PM
                                        • chth96
                                          by chth96
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          by chth96
                                          06-02-2024, 07:31 PM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
                                        • chth96
                                          Should I replace polymer capacitor?
                                          by chth96
                                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                          Is this ESR value of polymer capacitor correct?...
                                          11-18-2022, 04:22 AM
