LCD Monitor with bad caps OSCON?
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    These OCSON pull out from the TINY 15" LCD Model: BJ350 It is was 8 years old.
    I am surprise the original color is that color or not?
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: LCD Monitor with bad caps OSCON?
    interesting one you have there Joe.
    the text on the caps looks authentic. but i have not seen them that colour (only purple for those kind of series) what happened inside that lcd? looks like very much heat.
    any pics of the lcd board?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      the lcd survive the fire?
      weird.
      • gonzo0815
        • Feb 2006
        • 1600
        hm, 8 years of high temp usage? where is the problem? Recap and have fun another 8 years.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          oscons i have seen are blue,purple,or red.
          cant tell much from the pics but those look like fire victims.
          • Big Pope
            Approved Vendor
            • Dec 2005
            • 426
            Yup, i have saw the purple OSCON only. The LCD monitor will shut down automaticlly within 1 second now. There is some bad smell on from LCD, i guess the internal power supply is burn. LCD circult board will upload here later.
            weird.
            It is not survive the fire, there are also some other E-Caps crap, like 1 pcs of 100uF 25v and 100uF 400v(big size)!
            May be you are right, i guess there is very high temp inside for a long time. By this reason, OSCON outlook was affect by the high temp for a very long time, so it seems look like burn by fire.
            • Big Pope
              Approved Vendor
              • Dec 2005
              • 426
              Updated. The problem is fixed now.
              • Big Pope
                Approved Vendor
                • Dec 2005
                • 426
                100uF 400v crap...
                • Big Pope
                  Approved Vendor
                  • Dec 2005
                  • 426
                  Forgot to mention 4 pcs OS-CON was recapped with 3 pcs Samxon E-caps and 1 old purple OS-CON.
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Argh, those Elite caps are widely used in many CRT`s. Especially many Medion 17 and 19" are kontaminated with them in the main SMPS. But ok, they aren`t desinged to last more than 3 years. Most of them are failing earlier, due to bad soldering, a bunch of worser badcaps than Elite and bad manufacturing (e.g. loosening concetors).
                    • black6host
                      Replacement caps for Samson Resolv studio monitor 65A Amp board.
                      by black6host
                      Good day!
                      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                      I'm going to replace the caps and I'll be the first...
                      02-06-2024, 08:22 PM
                      by momaka
                      03-15-2023, 10:17 PM
                      by momaka
                      03-12-2025, 03:42 PM
                    • keepread
                      Dell monitor PSU vs Dell laptop PSU
                      by keepread
                      Hi there!
                      Someone gave me their old monitor, it's Dell S2715ht.
                      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                      10-30-2025, 04:45 PM
                      Westinghouse L2210NW LCD monitor - bad caps repair
                      by momaka
                      Here's another LCD monitor repair: Westinghouse L2210NW.
                      Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                      I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                      Pictures of the monitor outside/case after a brief...
                      01-11-2021, 01:14 AM
