bad caps of the 1990's played havoc with car ECU's
  • image079
    • Dec 2012
    • 8
    • australia
    Re: bad caps of the 1990's played havoc with car ECU's
    Hi. I have a 1993 Camry. It has done over 300 000kms. In the last year it has developed a bad idle on start up but improves when warm. Engine is very good, excellent compressions, excellent sparks. I have spent many hours probing all the sensors and have found no problems. I have also replaced coolant sensor, oxygen sensor, MAP sensor, ignition coil.
    Checked plugs, checked leads, cleaned idle control motor, checked throttle position switch, cleaned EGR valve, cleaned all terminals.
    As a last straw I was about to fork out the money for ECU.
    Anyway, I found this site and so decided to pull out the ECU out to check the Capacitors, and what do you know... it looks just like the photo above. Leaking caps galore. I will post pictures soon after I have a go at the repair.
      • 30997
      did you check the idle-air bypass on the throttle body is not clogged with crap?
      it's common on honda's
      • image079
        • Dec 2012
        • 8
        • australia
        Yes. Throttle body cleaned, Idle air control cleaned and probed.
        Anyway I removed the ecu and have taken photos of the leaky capacitors.
          • 30997
          you got lucky, that looks like some of the late 90's honda ecu's
          those leak and go up in flames!!
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i have fixed a cubic shitload of those.
            looks like you caught it before it got real bad.
            watch for eaten traces and ones with black under the coating.
            • image079
              • Dec 2012
              • 8
              • australia
              #26
              I went ahead and changed out the two leaky capacitors and I can confirm that IT IS FIXED!!!!
              Idles perfect from start up, NO Hesitation and NO Flat spot on acceleration.
              I can feel a noticeable gain in low end torque.
              In the last year it has gotten very sluggish, which I just put down to engine getting old. Now, it is back to how it was when I first bought it.
              I am hoping that fuel economy will also improve, because lately I have needed to fill up, way too often.
              I only changed out the 2 leaky capacitors. These were Michicon (PF) 47uF 63v (Brown) Capacitors. I read on another site that these (PF) series caps are the ones that always go bad. The other 4 on the circuit board look to be of a different brand and show no leakage. I don't know much about capacitors and my soldering skills are limited, so I decided to leave these for now. There was one trace which was almost eaten all the way through, so I decided to solder in a small length of wire. I made sure to solder both sides of the board where the capacitors are, because the PCB looks to be a double sided board.
              The car is a 1993 Toyota Camry 2.2 CSi Manual Gearbox.
              I took a few pictures of the capacitors installed.
              • theOracle
                • Nov 2012
                • 163
                hello from Club Lexus! - it's me, LSCowboyLS who wrote the original thread
                __________________
                the BIG 4
                ~~~ the top tier of low-ESR electrolytic capacitors ~~~
                  master hoarder
                  • May 2008
                  • 12170
                  • Bulgaria
                  #28
                  Nice work image079!
                  However, I can't help but mention that your new green "LOW ESR" caps appear to be of very questionable quality (probably cheap Chinese caps). Be prepared to do this again sometime soon, especially if the ECU is in a spot that gets hot. And keep in mind they may not necessarily bulge like the old ones did. They can just go bad without any visual signs whatsoever. So if the car starts acting up again, change those caps again.
                  And for next time, get good genuine Japanese caps (see theOracle's sig right above my post). Avoid eBay! There's only very few good sellers on there. Most just sell junk. Try Digikey, Mouser, Farnel, RScomponents, or even this place (badcaps.net).
                  • theOracle
                    • Nov 2012
                    • 163
                    an even more important reason to avoid ebay, is that it is not just enough to get one of the 4 high-end brands of caps listed in my sig, but you must have chain of custody due to there being so many counterfeits out there.
                    I decide on a brand of capacitor that meets the spec I am seeking in order to fix an ECU, then I go to the manufacturer's website and look at their list of authorized distributors and only source from those sources - you would not believe the good fakes I have seen on ebay, even from sellers with 100% feedback, (they don't even realize they are fakes!) - even your local mom & pop electronics store could have fakes and not know, they are that good!
                    __________________
                    the BIG 4
                    • pc7fan
                      • Aug 2013
                      • 52
                      ^^Could not agree more! Always use quality capacitors, especially in critical applications like this. These crappy caps should be only used on non critical equipment and on hobby projects.
                      • dreamlayers
                        Weird clipping on Logitech Z-10 speakers
                        by dreamlayers
                        I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                        05-22-2025, 11:41 AM
                      • howardc64
                        Samsung UN65NU6950 edge lit TV LED bar after 10k usage hours
                        by howardc64
                        Edge lit LED TV has 1/4 section backlight out. Replaced the LED bars and sharing the findings on the original 10k hour LED bar.
                        These are 6V LEDS (reads ~5.4+ on my LED tester) New bars read about 147V per 1/2 of each bar. Clearly original LED bar has some problems
                        • One section is 153v with a dead LED so clearly built up resistance
                        • One section flickers but magically fixed itself after driving individual LEDs. All done with an LED tester so don't know if would work driven by PSU backlight circuit and how long it would last
                        • Connector pin to test pad resistance is nearly 0 ohms.
                        07-07-2025, 12:18 PM
                        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                        by sam_sam_sam
                        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                        I bought this from an eBay seller but unfortunately they only had one
                        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                        I bought three of from them to also make battery packs with this output power limit in mind
                        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                        04-23-2025, 05:50 AM
                      • Loretto
                        Samsung SMPS BN44-00339A
                        by Loretto
                        this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                        I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                        I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                        I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                        03-29-2025, 08:30 AM
                      • Loretto
                        by Loretto
                        03-28-2025, 10:28 AM
