bad caps of the 1990's played havoc with car ECU's
  • image079
    • Dec 2012
    • 8
    • australia
    Re: bad caps of the 1990's played havoc with car ECU's
    Hi. I have a 1993 Camry. It has done over 300 000kms. In the last year it has developed a bad idle on start up but improves when warm. Engine is very good, excellent compressions, excellent sparks. I have spent many hours probing all the sensors and have found no problems. I have also replaced coolant sensor, oxygen sensor, MAP sensor, ignition coil.
    Checked plugs, checked leads, cleaned idle control motor, checked throttle position switch, cleaned EGR valve, cleaned all terminals.
    As a last straw I was about to fork out the money for ECU.
    Anyway, I found this site and so decided to pull out the ECU out to check the Capacitors, and what do you know... it looks just like the photo above. Leaking caps galore. I will post pictures soon after I have a go at the repair.
      • 31187
      did you check the idle-air bypass on the throttle body is not clogged with crap?
      it's common on honda's
      • image079
        • Dec 2012
        • 8
        • australia
        Yes. Throttle body cleaned, Idle air control cleaned and probed.
        Anyway I removed the ecu and have taken photos of the leaky capacitors.
          • 31187
          you got lucky, that looks like some of the late 90's honda ecu's
          those leak and go up in flames!!
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i have fixed a cubic shitload of those.
            looks like you caught it before it got real bad.
            watch for eaten traces and ones with black under the coating.
            • image079
              • Dec 2012
              • 8
              • australia
              #26
              I went ahead and changed out the two leaky capacitors and I can confirm that IT IS FIXED!!!!
              Idles perfect from start up, NO Hesitation and NO Flat spot on acceleration.
              I can feel a noticeable gain in low end torque.
              In the last year it has gotten very sluggish, which I just put down to engine getting old. Now, it is back to how it was when I first bought it.
              I am hoping that fuel economy will also improve, because lately I have needed to fill up, way too often.
              I only changed out the 2 leaky capacitors. These were Michicon (PF) 47uF 63v (Brown) Capacitors. I read on another site that these (PF) series caps are the ones that always go bad. The other 4 on the circuit board look to be of a different brand and show no leakage. I don't know much about capacitors and my soldering skills are limited, so I decided to leave these for now. There was one trace which was almost eaten all the way through, so I decided to solder in a small length of wire. I made sure to solder both sides of the board where the capacitors are, because the PCB looks to be a double sided board.
              The car is a 1993 Toyota Camry 2.2 CSi Manual Gearbox.
              I took a few pictures of the capacitors installed.
              • theOracle
                • Nov 2012
                • 163
                hello from Club Lexus! - it's me, LSCowboyLS who wrote the original thread
                __________________
                the BIG 4
                ~~~ the top tier of low-ESR electrolytic capacitors ~~~
                  master hoarder
                  • May 2008
                  • 12175
                  #28
                  Nice work image079!
                  However, I can't help but mention that your new green "LOW ESR" caps appear to be of very questionable quality (probably cheap Chinese caps). Be prepared to do this again sometime soon, especially if the ECU is in a spot that gets hot. And keep in mind they may not necessarily bulge like the old ones did. They can just go bad without any visual signs whatsoever. So if the car starts acting up again, change those caps again.
                  And for next time, get good genuine Japanese caps (see theOracle's sig right above my post). Avoid eBay! There's only very few good sellers on there. Most just sell junk. Try Digikey, Mouser, Farnel, RScomponents, or even this place (badcaps.net).
                  • theOracle
                    • Nov 2012
                    • 163
                    an even more important reason to avoid ebay, is that it is not just enough to get one of the 4 high-end brands of caps listed in my sig, but you must have chain of custody due to there being so many counterfeits out there.
                    I decide on a brand of capacitor that meets the spec I am seeking in order to fix an ECU, then I go to the manufacturer's website and look at their list of authorized distributors and only source from those sources - you would not believe the good fakes I have seen on ebay, even from sellers with 100% feedback, (they don't even realize they are fakes!) - even your local mom & pop electronics store could have fakes and not know, they are that good!
                    __________________
                    the BIG 4
                    • pc7fan
                      • Aug 2013
                      • 52
                      ^^Could not agree more! Always use quality capacitors, especially in critical applications like this. These crappy caps should be only used on non critical equipment and on hobby projects.
                      • dreamlayers
                        Weird clipping on Logitech Z-10 speakers
                        by dreamlayers
                        I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                        05-22-2025, 11:41 AM
                      • Sisko
                        Onkyo-593 No power and now clicking sound
                        by Sisko
                        Hi all!!
                        Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                        Yesterday, 02:18 PM
                      • EvazX
                        ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                        by EvazX
                        I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                        Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                        For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                        However, after some time, the replacement motherboard...
                        08-25-2025, 06:09 PM
                      • zklgfs
                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                        by zklgfs
                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                        08-11-2025, 02:14 PM
                      • pecman
                        Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
                        by pecman
                        I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
                        08-05-2025, 10:10 AM
