Help identifing this part. Picture included.
  • seajayemm
    • Feb 2013
    • 8
    • US
    I bought this non working Vizio tv, opened it up and found a bad voltage regulator (circled in the picture). I was getting a reading of .58v on the adjustment leg. I have searched the past 3 days on the internet for a replacement but have gotten nowhere.
    IIC?
    1084
    0808BL
    is printed on the top of it.
    I would appreciate any help identifying a replacement for this. Thanks in advance.
    Re: Help identifing this part. Picture included.
    What is the output between the Adj and the Output pin, it should be 1.25V.
    Are there 1 resistor connected between the adj and Ground, and another one between Adj and Out pin? What do you have at Input?
    • seajayemm
      • Feb 2013
      • 8
      • US
      I have labeled the voltage readings for the regulators in the picture. I found another (smaller one) that has a 0.00v reading on the adjustment leg.
      • seajayemm
        • Feb 2013
        • 8
        • US
        When plugged in the Vizio power indicator is lighted orange, when powered the orange turns to white, the back light fires up. The screen lights up gray. I get no response from the power, volume, channel, etc buttons on the side once turned on. I would rather pay a few bucks to repair the board than dishing out $100 for a replacement board.
        • seajayemm
          • Feb 2013
          • 8
          • US
          Thread can be closed. I found the faulty regulator and just paid for a replacement. Will post back the results after I slap it in.
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            I'm going to guess that the faulty part was an LT1084 or a clone thereof.
            PeteS in CA
            • seajayemm
              • Feb 2013
              • 8
              • US
              I suspected the regulator with the red star was at fault reading 0.00v on adjustment pin, 1.25v on the output pin and 2.06v on the input pin. I swapped a new one in and now getting a reading of 0.00v on adjustment pin, 1.25v on the output pin and 2.06v on the input pin. Anyone have any input on this?
              • mariushm
                • May 2011
                • 3799
                2v is uncommon, should be at least 2.5v or 3.3v, or 5v...
                The linear regulator needs at least about 1v-1.3v above its set output voltage to give stable output voltage, so it's not possible to output 1.8v from 2v.
                Follow the trace going to the input pin, measure the voltage at various points, see where that 2v comes from.
                For example, the 2v could be coming from the power supply and was supposed to be 3.3v or some voltage, but a capacitor has failed somewhere and made the voltages go all over the place.
                The easiest way to check this, is to measure the voltage on the connector coming from the power supply.
                Ah, looking back at the picture I see 3.3v, 1.82v , 1.25v ... so yeah, follow the input pin and discover why it's so low value. Measure the other voltages...
                Here's a good video in which the guy has a similar problem, low voltage on one of the power supply outputs.. :
                http://www.youtube.com/watch?v=8k27lQFpNZs
                Look how he measures the voltages and how he reasons and see if it helps you.
                • seajayemm
                  • Feb 2013
                  • 8
                  • US
                  Got tired of messing with it. Went ahead and ordered a new main board. Should get it back Friday, will post results after I swap them out.
                  • mariushm
                    • May 2011
                    • 3799
                    Yeah, well if the power supply board is bad, that board with the voltage regulator will still see 2 volts.
                    Won't hurt you anything to measure some voltages while you wait.
                    • seajayemm
                      • Feb 2013
                      • 8
                      • US
                      I measured voltages coming into the main board (the board I ordered) I found no readings of lower than 3.3vs. When I put the new board in I will take some more readings and compare them with the old board and try to pinpoint the problem, then repair the old board.
                      • selldoor
                        Slow Learner
                        • 7870
                        The output from the regulator old and new seems to be correct at 1.25v
                        (as Budm say in post2)
                        As in Post8 you need to trace from the 3.3 you say is coming in to the board to the regulator BUT if the output is 1.25v and that is correct it doesnt really matter?
                        • seajayemm
                          • Feb 2013
                          • 8
                          • US
                          The person I bought the main board from said he could not test it completely and guarantee it was 100% good so he refunded me my money. He also told me his technician said that 90% of these models tvs have problems with the daughter board, that most people replaced the main board to not fix the problem. So I ordered a daughter board from shopjimmy for a third of the price of a main board. For now I will patiently wait for it to arrive.
                          • edugimeno
                            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                            by edugimeno
                            Hi There!
                            I'm trying to help my friend who owns a restaurant be just bought.
                            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                            It's stuck using, I guess, the 2 sided tape that comes with the strip
                            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                            09-05-2024, 09:34 AM
                          • G-Sting
                            iPad Pro A1876 SHORT Part Identify Help Needed
                            by G-Sting
                            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                            SO My main concern is what part should i order what should i search the name for ?
                            on Ipad...
                            05-15-2025, 09:30 AM
                          • JJAAMM
                            by JJAAMM
                            Problem
                            07-06-2023, 06:01 AM
                          • TR103
                            by TR103
                            - it keeps rebooting
                            01-22-2025, 04:12 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
