-------------------------Introduction---------------------------
I have a AMD Athlon 64 System i build for a friend there. This thing gaves me always headaches. it is build around
a ECS Nforce4-A939 board,
A64 3000 Winchester
2x 256Mb Kingston VS DDR400
and a MSi 6600GT Nx6600GT-TD128E, PCB 8983 v 2.0.
Now this system was problematic right after begining. If all 3d apps get frozen very soon. I managed to get it halfway stable with the NV betadriver, but random freezes in 3d apps are continiuely reported by user.
I swaped PSu with my Amacrox Frei Erde AX550GLN, wich did not help.
So i blamed the ECS board, as they are using usually poor ost caps. But i havve seen many users with no problems on that board. And even OC with this system was no problem, Prime95 memtest no problem only 3d apps.
I looked today again on this board, and i can`t say anything than that this board is well made in any way beside the OSt caps.
--------------------------END---------------------------------
Now i googled a bit and compared the similar build 6600Gt from other vendors and was a little supprised, as any other vendor used only Oscon or other solid polymer caps, only MSI has the balls to swappe 2 of them with 1000Uf KZG 6,3v caps.
All other brands are using 1200uF 4v SVP series. Immagine that. I think you all know the diffference.
I am tempted to swapp thos KZG with some MCZ 2200uF, wich will probably come close to the ESR specs of the Oscon caps. Shure it will look very ugly, but i only have some 2,5v 2700 Oscons there, i duno if this is ok for the Vcore of this card.
here some picture to see the difference:
MSi: http://www.eltris.pl/zdjecia/608.jpg
http://www.3dnews.ru/documents/12529...-front-big.jpg
The good ones:
http://www.ixbt.com/video2/images/xf...scan-front.jpg
http://images.google.de/imgres?imgur...lr%3D%26sa%3DN
http://www.kohryu.com/picture/inno/gf6000/6600gt.jpg
As you can see, all the same PCB i think.
PS: i linked the pics, as i duno if i void the copyright if i upload them. They are all marked....
A64 3000 Winchester
The good ones:
still working same performance in the end)
