Qualitative analysis of Capacitors?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Anyone actually have gear to do qualitative analysis on capacitors?
    I mean, have a bake oven and a high frequency high current "zapper" that will torture test capacitors until they fail?
    Granted capacitors tend to vary from lot to lot, and even unit to unit, but perhaps some of the "bad" cap manufacturers got their act together and make some semi-decent caps now?
    master hoarder
    • May 2008
    • 12175
    Re: Qualitative analysis of Capacitors?
    My friend baked the caps on quite a few Xbox 360 boards while he was setting his reflowing machine. Those 360 boards have good caps on them, though (Rubycon, Panasonic, Nichicon, etc.) so the results weren't all that spectacular.
    What I noticed is that some caps will bulge right after being overheated while others would take a week or two to bulge after they were overheated. And what's even more interesting is that most of those caps that bulged right after being overheated, I could push their tops back down, meaning there was only temporary pressure buildup. Checking them with a capacitance and ESR meter after they bulged and a few weeks after pushing their tops down didn't reveal any significant changes in their properties. In fact, I have used a few such caps to recap a motherboard of mine. They tested fine for capacitance and ESR for over a month after I pushed their tops down, so they are likely going to be fine.
    However, for the caps that bulged a few weeks after they were overheated - on those I usually couldn't push the tops back down, meaning some of the electrolyte must have broken down and there is a permanent gas buildup in the cap which will lead to eventual failure. On those, I noticed the ESR was slightly degraded.
    I don't know if the above is a unique case or not, since I only tested that with about 20 caps. But it seems like if there is no permanent pressure build up in the cap and if the cap didn't leak any electrolyte, then it might work just fine.
    • mockingbird
      • Dec 2008
      • 5488
      There are some interesting posts by Pete in CA regarding this in this thread:
      At my, now, previous employer I compared HD with HE for a very different usage than what folks here do. I was not impressed. Then again, I was subjecting the things to 7X-10X (not a typo!) the rated ripple current, not anything like P/S or VRM usage. Generally, Nichicon PW, PA & HE, Panasonic FC & FM, Rubycon ZL, and UCC LXZ and KZE series did best in my torture test. That was over 3 years ago, BTW.
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        Very briefly, I had a tester that used an LM317 to create an adjustable constant current (datasheet app) that then fed a square wave push-pull inverter. The transformer ratio stepped down the voltage and stepped up the current. The output side of the transformer was loaded by the cap being tested.
        As I said in what mb quoted, the ripple currents were literally 7X-10X the parts' rating. The tests were open air, room temp. With a few of the smallest caps I tested (12.5mm diameter) the current fused the lead wires. Under that torture, the best parts often ran for hundreds or over a thousand hours before venting. Most of the deterioration in impedance happened toward the very end of the parts' lives.
        PeteS in CA
        • KD0CAC
          • Dec 2012
          I've used a Hipot tester to test large vacuum caps like Jennings , a couple of the Hipot testers have 3,000 AC , 4,000 or 5,000 AC/DC volts ,
          http://www.surplussales.com/vaccumvarcaps/VVC6.html
          • Paddan1000
            • Mar 2013
            • 17
            • Sweden
            I'm resurrecting this thread because I'm very interested in reading some reports where they compare caps of different brands and origins by having them endure standardized torture tests.
            Most reports of bad capacitors seem to be anecdotal and usually involving 10+ years old capacitors made during the great capacitor plague.
            If anyone know of any studies, please post a link.
            • Paddan1000
              • Mar 2013
              • 17
              • Sweden
              I just desoldered a 10V 3300uF Teapo capacitor from a FSP PSU that I bought in 2006 and have abused daily for about 5-6 years in a badly ventilated computer way too power hungry for it's rated wattage. It showed no bulging or leakage. The capacitance was 3600uF (9% above rating) and the ESR somewhere between 0,05 and 0,00.
              Clearly Teapo (and the Capxon that also were present in the PSU) can't be as bad as people say if they survived all those years in a budget PSU without losing their specifications.
              • tron
                • Apr 2009
                • 47
                There is no great capacitor plague,
                there are quality caps, and
                not so good quality caps
                (Toepo, CapXon, ....not good)
                plenty of bulging(Capxon)/
                losing capacity(Teapo)
                examples among them
                • Rulycat
                  • Apr 2010
                  • 724
                  I find that with cheap capacitors like Teapo the main problem isn't that they never make them well... it's that they don't make them consistently to begin with.
                  • Heihachi_73
                    • Jun 2012
                    • 713
                    It really is just hit and miss with the big Taiwanese brands. Teapo, CapXon, OST, and even Fuhjyyu can have caps work perfectly for years on end without being out of spec, yet other seemingly identical caps can fail after a year or two. I'll still take a Taiwanese brand over a Chinese brand any day.
                    I am even thinking that the companies themselves are outsourcing or have separate factories - why do Teapo caps have completely different bungs for example? I've seen Teapo bungs with many rings within rings (bullseye), I've seen ones with a single circle in the middle, and I've seen others which are split in the middle and stick out like a Rubycon bung rather than having the cap sit flat against the PCB. All of these I have come across were earlier than 2005, so it predates the G-Luxon merger.
                      master hoarder
                      • May 2008
                      • 12175
                      Yeah, I've noticed that too with Teapo. Indeed makes you wonder if there are different factories that make them. I have a big bag of Teapo SC 6.3V 1000uF 8mm caps pulled from HP DC5000 motherboards. I tried to see if there is a pattern among the failed ones and which ones (as in, by which bung design) failed the most. Couldn't really find a pattern, though. There were failures from almost each kind. Indeed they are just inconsistent.
                      • Wester547
                        • Nov 2011
                        • 1268
                        • USA.
                        ^ I strongly believe that G-Luxon gained large control over the Teapo's stock once they merged at the end of 2005/beginning of 2006. I have heard too many reports of Teapo failures -after- 2005 and not -before-... makes me wonder if 8mm Teapos and below are really G-Luxon and 10mm Teapos and above regular Teapos. But 1000uF, 6.3V Teapos have a rather low ripple rating and high ESR rating to begin with, especially if they measure 8x11 and not 8x15.
                        Depends on their date code. If they were manufactured in 2005 it could be predate the G-Luxon merger. However, 3300uF Teapos are rather overspec'd for the job to begin with.
                        • mockingbird
                          • Dec 2008
                          • 5488
                          This.
                          • Heihachi_73
                            • Jun 2012
                            • 713
                            Doesn't Teapo still use the G-Luxon brand? They show both Teapo and 'Luxon' in their datasheets, so if anything, all G-Luxon caps this side of 2005 are Teapo anyway. Maybe it's time to open up a few and see what the innards look like, along with the electrolyte used.
                            • lti
                              • May 2011
                              • 2558
                              I think the ones made by G-Luxon still use the X-shaped vent.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8711
                                I wonder what conditions they use to test capacitors? When a company specs 5000 hours at 105C, how do they run the capacitors? I wonder if small (say, few tens of millivolts), frequent (1MHz) discharges is more stressful than large (say, near full rail) but less frequent (perhaps 10s of Hz) discharges?
                                This is still a good 7 months worth of testing which is a very long test... but still would be interesting.
                                • dragon3x
                                  by dragon3x
                                  power on.
                                  Here are some examples :
                                  switching supply area).
                                  than 6.3 V.)
                                  03-21-2025, 02:46 PM
                                • slybunda
                                  AA and AAA battery charger capacitors?
                                  by slybunda
                                  hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                  it has inside:
                                  2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                  2 x 470uf 16v LZ105c branded as G.Luxon
                                  not heard of these brands are they any good?
                                  iv attached photos of the charger and the board inside for an idea on the type of...
                                  12-24-2023, 04:41 AM
                                  After all of...
                                  07-13-2024, 08:14 PM
                                • Cama
                                  Solar Inverter - SMH-II - 2 missing capacitors
                                  by Cama
                                  I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                  My model is : EASUN SMH-II 7 KW
                                  Mother Board : P/N 18947-002401250250
                                  Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                  Thank you...
                                  09-12-2025, 02:50 AM
                                • Ady2017
                                  Are there any datasheets available for Elna RJG capacitors?
                                  by Ady2017
                                  I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                  05-25-2025, 02:19 PM
