Eurocase Hec cap exploded
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    Guys, we all know that Eurocase PSUs aren't nowhere near good. On top of that, they use the inferior Hec caps. So, when the metal meet the meat, it could end like THIS:
    (take note that the cap exploded AND broken the small PCB on the main's connector!)
    (check out how the resistor was hot!)
    (and the rests of the cap - well, it is not my quality macro, but you get the idea...)
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Eurocase Hec cap exploded
    the little motherfucker
    • Rainbow
      • Aug 2005
      • 1375
      See the burnt resistor near KA7500B chip? Check the area between the two heatsinks - you'll see discolored brown PCB. That cap exploded because of too high voltage applied to it - as a consequence of auxiliary supply failure - a classic EuroCase problem - as seen here https://www.badcaps.net/forum/showthread.php?t=831
      It needs some more work to fix it now - so if you have more of these PSUs, replace the cap mentioned in that thread.
      • yanz
        • Nov 2004
        • 910
        i'm very familiar with those heatsinks and those burnt components.
        but in my country, usually those psus are without i/p filter and pfc. ye sthey use hec too. perhaps hec caps and hec (heroichi) psu is a different company (?)
        days are so short when you actually do something..
        • Shroomie
          • Apr 2006
          • 356
          That little bugger most've made a good bang... Hate to see what it did to the rest of the computer when it went.
          You know there's something wrong when you open up a PSU and are glad to find Teapos.
          Why I don't buy cheap cases!
          • Rainbow
            • Aug 2005
            • 1375
            Sometimes it just dies without damaging anything, sometimes it puts out a voltage spike that kills almost everything.
            • tiresias
              • Feb 2006
              • 489
              Monstrous! That PCB isn't fixed in a position where it would be very rigid, which means the cap in question must have struck it with a considerable amount of force.
              Could you show us the other side of the PCB, where the impact took place?
              • trodas
                • Jan 2006
                • 770
                • Czech republic
                willawake - he it little, tough he can do "great" things...
                Rainbow - no-one is going to fix that crap Yet thanks for providing a solution, mate! And in this case, IIRC, nothing get damaged in the machine - hooray!
                Shroomie - exactly my point. Maybe the cap could be used as shell in gun?
                tiresias - I can't. This is pictures + short info that send me my friend of what happend to his friend. That is all
                • Big Pope
                  Approved Vendor
                  • Dec 2005
                  • 426
                  Trodas, PCB is not good for this PSU. Be careful if want to recapp or repair this PSU.
                  My SAMXON Capacitors Database HERE!!
                  X-CON is a new brand for SAMXON's Polymer Capacitors.
                  • trodas
                    • Jan 2006
                    • 770
                    • Czech republic
                    Hehe, no way. I won't touch this one with ten foot pole
                    • AJ847.63e
                      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                      by AJ847.63e
                      Hi Folks,
                      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                      05-06-2025, 10:37 PM
                    • Bivolalbert
                      Help figuring out the resistance of this exploded resistor. gtx 1060 6gb inno3d compact
                      by Bivolalbert
                      Hello,I need help figuring out the resistance of this exploded resistor. I'm pretty sure it's the one labeled R37. I tried measuring it with a multimeter, but I got different values each time, probably because it's exploded. If you have a schematic, it would be really helpful!
                      Its a gtx 1060 6gb inno3d compact, i you have schematic it would be very helpful....
                      02-13-2025, 10:30 AM
                    • hikomalek
                      SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                      by hikomalek
                      Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                      When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                      Transformer:
                      |Info| Primary | Aux | AB | CD|
                      |Ratio|1|25|40|12|
                      |Voltage AC|230V|9.2V|5.8V|19V|
                      |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                      I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                      09-19-2025, 03:30 AM
                    • iminusjk
                      Lenovo Yoga Pro 9 14IRP8 - help identifying what exploded in the motherboard
                      by iminusjk
                      I hope this finds you doing well.
                      I need some help identifying what and how important is that exploded in my laptop's motherboard.
                      Photos attached.
                      My laptop is a 1 month old Lenovo Yoga Pro 9 14IRP8 (83BU), i9-13905H, RTX4070, 64 GB ram.
                      It was in the charger, and I was excited to play FC24 for the first time, but when the loading screen came something exploded in the laptop and it shut down.
                      It didn't turn on for about 30 seconds after that, but then it turned on and has been working seemingly perfectly (at least I didn't notice...
                      12-21-2023, 01:30 PM
                    • Satdude
                      Yamaha RX-479 PSU exploded
                      by Satdude
                      Hi, I have a Yamaha RX-497 receiver, and one day I came home to a burnt smell and the breaker was tripped. Upon opening the receiver, I saw extreme damage to the main power board. C254 was exploded, R261 was burnt, D255 was shorted, Q254 is open circuit, D261 (bridge rectifier) is also open, traces to IC252 (TC4013BP) are vaporized right off the board. Not sure about any other damage, I'll have to desolder the flip flop to test it. Also the transformer T251 is getting hot when plugged in. What could have caused such extreme damage just sitting plugged in? Only repair that was done in the past...
                      04-18-2024, 05:54 PM
